Playing back clips from P2 card? at DVinfo.net
Old March 22nd, 2007, 07:55 AM   #1
I borrowed an HVX200 yesterday to do some experimenting, and am stuck trying to figure out how to play back clips recorded to the P2 cards. I'm in MCR mode and have the clip I want to play selected in the thumbnail list, but when I push the "play" button on the top controls nothing happens. Is there something else I need to do to get the clips to play?
Old March 22nd, 2007, 08:08 AM   #2
Hello Kevin,
Make sure you are in the mode that the clip was recorded in.
If recorded 720 24pN you need to have the record mode set to that setting.
Mike Schrengohst
dvd.pro@verizon.net
Mike Schrengohst is offline   Reply With Quote
Old March 22nd, 2007, 08:12 AM   #3
Mike: I saw a note about that in the instruction manual but I'm not sure how to change it. Clips were recorded in 720/30pn but the viewfinder is showing 720/24pn. Where do I reset that for playback?
[Update: I used the menus to switch to "same type" clips and then the playback worked.]
