Can you recommend a good tripod head to use with the HPX500 - Page 2 at DVinfo.net
Old July 14th, 2007, 11:16 AM   #16
Vinten VISION 8
I have the Bogen 501 head/Manfrotto 525MVB tripod kit already. I had the Vinten rep bring the Vinten VISION 8 system over and we compared the two tripod systems head to head. We used my fully rigged Ikegami HL-DV7AW(two IDX batteries, Sennheiser wireless rcvr and Frezzi MiniFill) for the test. There really wasn't any contest. The Vinten was far smoother and stable no matter how we angled it. If you accidentally put substantial pressure down on the camcorder body the tripod legs were rock solid (no sliding). Whereas my Manfrotto legs slid unevenly down about 1 1/2" on two of the legs. The Vinten head/tripod combo also had enough residual capacity to properly tension the weight for a teleprompter or other heavy accessories like a 8" LCD HD quality monitor with it's own IDX battery. But at almost $5K for the Vinten compared to my Bogen/Manfrotto at under $1K, I wasn't suprised with the performance differences. If I get the HPX500 I'm going with the Vinten VISION 8 unless I get convinced otherwise.
The BH Kit: Vinten VISION 8 Carbon Fiber Tripod System: Vision 8 Fluid Head, 2-Stage Pozi-Loc Tripod, Mid-Level Spreader and Softcase - Supports 31 lbs Mfr# V8CP2M • B&H# VIVIN8CP2M
Douglas Call is offline   Reply With Quote
Old July 14th, 2007, 11:38 AM   #17
The 501 head is fine for DVX sized cameras, anything larger is out of its resitance range, just too heavy.
Old July 14th, 2007, 02:54 PM   #18
Originally Posted by Dan Brockett View Post
I am currently using a Sachtler Video 6SB paired with the Miller Solo DV carbon legs with the HVX-200. I am very happy with the setup, it is superb.
Hi, I second what Dan said and also quite happy for having listened to the advice from Dan back when I bought my kit.
I have the similar setup, but not the Solo legs, my legs are from Gitzo, very similar shape, weight and features to the Solo. (Miller has lousy network in Europe, thats why I had to find an alternative).
Highly recommended setup, works perfect.
Sony XDCAM EX1r, Canon 5DMkII, Røde NTG2, Røde NT1000, Røde Stereo Videomic, Sachtler DV6 SB on Gitzo 1325V, Steadicam Merlin, Omnitracker, Hackintosh 3.5Ghz Quad 8Gb RAM
Zsolt Gordos is offline   Reply With Quote
Old July 14th, 2007, 05:06 PM   #19
What is the smallest Sachtler you could get away with for the HPX? Would a DV8-SB work? i think the max payload is 26.5 lbs? (2,800.00 U.S)
Brian Ladue is offline   Reply
