Casio EX-F1: changing shutter/aperture at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
HD from Nikon D90, other still photo cams (except EOS 5D Mk. II, LUMIX GH1).
Old April 9th, 2009, 04:52 AM   #1
It would seem that changing the Aperture or Shutter speed applies ONLY to HS-movies. STD and HD are totally unaffected!
So changing the Shutter speed applies ONLY to HS-movies. But because HS300 normally uses 300 frames per second, only shutter speeds higher than 1/300 are applied. So you can use for example the shutter speed of 1/4000 and it works, but if you use something like 1/60, well, of course it won't work. :)
It seems strange that changes to Aperture and Shutter speed work only in HS-movies but not in STD-movies or HD-movies.
Janne Miettinen is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
