NEX with heatsink? at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
HD from Nikon D90, other still photo cams (except EOS 5D Mk. II, LUMIX GH1).
Old June 20th, 2012, 12:01 PM   #1
NEX with heatsink?
Hi guys,
I've read that some people have been using RAM heatsinks to cool down their NEX cameras (5, 5N, 7, etc). Has anyone here tried this solution and successfuly overcame the overheating issue with the NEX cameras?
8 Copper RAM Heatsink Heat Spreader SD/DDR SDRAM DDR2 | eBay
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old June 27th, 2012, 03:09 PM   #2
Contributor
Re: NEX with heatsink?
I have an NEX-7 and haven't experienced any heating problems. When I first got it I let it run for over 25 minutes. It was sitting down flat on a tabletop, and the warning light came on. After it went off, I put the camera on a tripod, opened the LCD and no more issues. Under normal use it's never heated up. But if yours does, that might be a good idea.
Old July 4th, 2012, 02:55 AM   #3
i bought a 5v CPU fan and wire it to a USB connector, then powered it from a USB battery bar
It will cool it down
Thomas Wong is offline   Reply With Quote
Old July 4th, 2012, 08:38 PM   #4
I tried the heatsinks and it did nothing.
Sony Fan Boy! Sony AX100, VG20, RX10, A6000, CX760 and a GoPro 4
Dan Tolbertson is offline   Reply With Quote
Old July 6th, 2012, 11:44 AM   #5
Is it true that 50MBPS Sony memory sticks run cooler than Class 10 SD cards?
Was thinking also of buying an AC adapter on EBAY, hooking up the battery adapter part to an external battery to eliminate heat from the battery.
Galen Rath is offline   Reply With Quote
Old August 7th, 2012, 08:19 AM   #6
Check this out, guys. This guys is using a battery powered ram fan with good results:
Sony NEX-5n/NEX-7/VG-20 news and reviews roundup… | sonyalpharumors
Old August 7th, 2012, 12:55 PM   #7
Keep in mind that ambient temperature is the villian - cameras don't "sweat", so the lowest temp air a fan can blow across the hot parts is ambient air temp, which may or may not be of much help in hot climates! Hot is still hot if you aren't using some form of active cooling other than blowing hot air over the surface...
Dave Blackhurst is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > Photo for HD Video (D-SLR and others)
