-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   best lighting kit for music videos ? (https://www.dvinfo.net/forum/photon-management/117830-best-lighting-kit-music-videos.html)
Matt Stedeford March 26th, 2008 09:09 AM
Can anyone suggest any links to the cheapest lighting kit that can achieve this:
http://www.youtube.com/watch?v=WUZ6ICMAeUA
I'm planning on doubling up the use of lighting for stills photography as well; save money.
So, I'm guessing daylight approx. 5600k or so temp will be needed? I'll be shooting music vids against black and white backgrounds, and chroma key, in a small dark room with no windows and editing in post to make it look bigger and do effects etc. Want enough power to bring out the colours and make it look glossy. How much power is needed? What type of lighting? (e.g. cool lights... flourescent... redheads....) Is cool lighting any good? (e.g. http://www.cameras2u.com/Store/s6267...t/details.aspx )
I'll want enough versatility to play with lighting and do a variety of shots (e.g. type of lighting as shown on above video... soft lighting with no shadows.. occasional high contrast lighting.. silluette lighting..etc), but would like to achieve results with minimum cost.
I've done lots of research, but at this point, am looking to see examples, ideas, and suggestions from people who have used the equipment and seen results.
Any advice appreciated! Thanks :-)
Matt
Bill Davis March 26th, 2008 01:41 PM
The cheapest lighting kit that can achieve this would likely be a 3-5 ton grip truck rented from a competent grip house and used by professionals that know what they're doing - in a light controlled studio setting.
Just from looking at the lights and shadows, I would guestimate that $15-25,000 worth of specialized lighting gear was used.
The "whiteout background scenes" alone would require a serious lighting grid with significant cyc lighting. And that's before you even considered lighting the dancer/singer.
You might be able to re-create a few of the more basic shots with a kit approach - but you simply can not recreate all these shots with a cheap kit and a converted room at home.
Sorry.
Matt Stedeford March 26th, 2008 02:39 PM
Sorry.
What would the grip truck be used for?
We are all entitled to our opinions, I just don't agree with you in this case.
Any more ideas welcome! :-)
Benjamin Hill March 26th, 2008 03:04 PM
If you don't even know what a grip truck is, how can you disagree with Bill's (practical) advice- advice you asked for?
Here's an idea: prove him wrong by doing it your own way.
Jack Walker March 26th, 2008 05:43 PM
The Grip Truck is full of lights, stands, reflectors, etc. etc. etc.
I did a weekend video project with a Betacam SP a number of years ago. We rented a truck for the weekend for the day rate of $275 (or maybe less, I don't remember exactly).
(I also hired a DP and 2 crew members, but that came in a bit more than the truck.)
I don't know what a truck rents for now, but I think you can get quite a bit for under $500.
But if you don't want to rent a truck, and you want to buy, then let's put the question this way: If I only have $300 and want to light a music video, would someone please list the 10 pro lights I should buy first? And what should I buy with the money that's left over? Thanks!
Richard Andrewski March 26th, 2008 08:48 PM
You don't necessarily have to shoot in front of white or black cycs to get those effects. You could shoot the entire thing in front of green screen (as long as you do it right and you get good keys) and replace the background with pure white or black. People do it all the time. Unless your key is good though, you probably won't like the effect as you'd see an outline around the person. Good separation between screen and subjects, good rim lighting to counteract green spillover, will be important to this.
And on the question of is fluorescent lighting any good, yes of course it is, people are using it successfully every day. Its used quite often now for cyc lighting on a green screen shoot for both subject and background. Just light in two layers. Subject has their own lighting and effects. Background lit evenly and smoothly without hot spots and white balance to the foreground/subject lighting with green screen lighting turned off. Then after white balance, relight the screen and shoot.
Ben Winter March 26th, 2008 09:13 PM
Matt I'm seeing a lot of edge lighting from overhead and the frontal lighting is clearly a very large soft lighting source. Suggesting a large setup and LOTS of watts. Something like a kit you linked to will not cut it.
On my website click the "morning for the masses" link and watch that--done with about 3,000 watts of tungsten, assorted 500 watters placed in certain areas and 2,000 watts shone at a bounce sheet to provide soft light from the side. I now have an addition 1300 watts from a soft fluorescent light source and it still isn't enough to achieve the lighting in that video you linked.
Sorry to say, Bill is mostly right here, although I don't think cycs were used, but rather chromakey.
G. Lee Gordon March 27th, 2008 10:48 AM
Hey guys, innocent bystander here. Don't attack me, but what's a cyc?
George Kroonder March 27th, 2008 11:58 AM
cyc, aka strip light, flood light.
From cyclorama: A cyclorama is a cylindrical panoramic painting designed to provide a viewer, standing in the middle of the cylinder, with a 360° view of the painting. (source: wikipedia)
Cycs are used to "paint the stage with light" you could say (welll I said it anyways).
George/
Steve Oakley March 27th, 2008 12:29 PM
I've seen chroma talking heads placed on white. reasoning was to get the same white behind everyone when video was shot in 6-8 different locations.
that said, the video was almost certainly shot on a white cyc. its a lot easier that way. large diffused frontal sources where used, 6X6 or 8X8 most likley. to light this that meant at least a 2K openface or 2 behind each silk, or a 5K. certainly a small 3-5 ton truck worth of gear.
the black shots most likely where done on a 20X20 solid. done this enough times, then crushed the blacks in post to eliminate any variations. could of done CK, but thats more of a pain then anything else.
then to get a longer lens and that look, you need to be able to get back 20 to 50ft with the camera, and that only happens in a suitable studio space.
no you can't do something like this in a small room. ain't gonna happen and look the same. you know people will spend $10k for a camera, but the won't spend $10k for lighting gear, even though that gear will last for the next several cameras. lighting and audio gear is a good investment, cameras poor.
and of course once you have the gear, you also need to crew to set it up because one person just can't move all of it fast enough....
better to rent a truck, hire a couple of grips, and do it right.
G. Lee Gordon March 27th, 2008 02:30 PM
Does anybody know a reliable company to rent a 3-5 ton truck with crew in Dallas/Ft Worth???
Richard Gooderick March 29th, 2008 02:06 PM
I don't know. Bill seemed to be trying to come up with a constructive answer and this response sounds sarcastic. Was it meant to be?
Bill Davis March 29th, 2008 08:08 PM
Cool. We disagree. That's healthy.
But please understand that I've had to light stuff like these scenes. And. forgive my presumption, but I suspect that you have not.
That's doesn't make me "right" and you "wrong" necessarily. It just means that I answered from a knowledge base of a couple of decades doing this kind of work to put food on the table. So for me it's less "theory" and more practical experience.
You picked scenes that were professionally produced with VERY high production values.
And if a $300 kit could produce the looks you referenced, I'd expect every kids school play would look just like your examples.
And they don't.
Worse yet, every school cafeteria probably has a few THOUSAND DOLLARS in lighting gear installed. And videos of school plays on those stages look NOTHING like your examples.
Yes, part of that is technique.
But part of it also is that several thousand dollar school stage lighting arrays are STILL NO WHERE NEAR capable of doing the kind of work you referenced.
So, I'm sorry you don't like the answer. But it's STILL the answer. You simply can't re-create the looks you're referencing without the proper equipment.
Simple as that.
Dan Brockett March 29th, 2008 09:59 PM
After looking at the video, Bill is undoubtedly right. You get this kind of look with 6ks punched through 12x12 muslin photographed on 35mm, not with a lighting kit. Those silky smooth skintones are from huge and powerful soft sources, not kit lights.
It's not the truck, its the material that the truck can carry. I personally own a 3 ton package but I don't own a grip truck. I can't fit huge lights, a big generator and 12x12 kits in my pickup truck. I think thats what Bill was getting at. a professionally done music video like this is done with big boy toys, it's look and feel cannot be replicated (at least very closely) with prosumer gear and a lighting kit.
Not to say you can't get a great look with smaller cameras, HD and a lighting kit, that's what I shoot with most of the time, but it won't have the same type of look as this promo does.
Dan
Nate Weaver March 29th, 2008 10:51 PM
1 Attachment(s)
Another voice for Bill.
There's a fair amount of instruments working here, and while you could approximate it with maybe a couple 2Ks and a couple 650s, it wouldn't be quite as polished. Bill knows what he's talking about.
Lemme show you the lighting order from a greenscreen shoot I did 2 weeks ago at Smashbox Studios in West Hollywood:
1 X 9-lite Maxi brute Complete (medium globes)
2 X 5K Baby Complete
2 X 6K Spacelight Complete
2 X 1K Baby Baby Complete
2 X 650W Tweenie complete
2 X 4' X 4 Kinoflo complete (globed tungsten)
1 X 5K Variac
3 X beefy baby stand
1 X premie stand
1 X 6' X 6' frame (now quantity 1)
2 X 10' speedrail
2 X speedrail ears
2 X lollipop
1 X menace arm kit (remove entirely)
1 X 6' X 6' 1/2 silk
1 X 6' X6' Full silk
1 X 4' X 4' #216 gel frame
1 X 4' X 4' #250 gel frame
1 X 4' X 4' Opal frost gel frame
2 X 4' X 4' silk
6 X 4' X 4' black flag w/ flop
2 X 4' X 4' bead board bounce
2 X 2' X 3' (of each below)
black flag
double net
single net
silk
2 X 18" X 24" (remove all 18x24 flags entirely)
black flag
double net
single net
silk
1 X 1' X 3' cutter (w/ flop?)
3 X 3-riser combo stand
2 X set of combo wheels
3 X 2-riser combo
3 X hi roller stand
2 X low combo stand
20 X C-stand
3 X baby C-stand
2 X Platypus clamp
2 X cartellini clamp
2 X mafer clamp
6 X aircraft cables
(leaving out all distro)
This all to produce just:
It's not even a truck's worth!
Bill Davis March 31st, 2008 01:05 AM
Matt,
And since you're clearly interested in learning about this stuff, look at Nate's photo and don't look at the model - look at the SHADOWS surrounding the model on the greenscreen material.
Don't see much and what there is is extremely soft and diffuse.
The greenscreen background is evenly lit, but even though she is ALSO evenly lit - notice how she isn't casting much in the way of shadows to mess up the way the green screen reads?
THAT is what you get with the right equipment in competent hands.
Just as with your examples.
Again, this simply can't be done with a few lights and stands.
Nate Weaver April 1st, 2008 10:48 PM
Just for anybody's info, in that setup, there was a forward mark the talent would land on where there was a nice key/fill ratio for some shape on the face. It was somewhat flat as the talent was farther away.
Key was camera right, the 9-light through a half-silk. Fill was a 5K camera left through a full silk.
Brian Luce April 27th, 2008 04:10 PM
Originally Posted by Bill Davis (Post 851386)
Matt,
Is that then an acceptable amount of shadow from the talent?
Also, if you wanted a matrix like white in a cyc, is it easier to use a white bg or green and drop in the white in post. I would think a real white bg would solve the spill issues that'v alwaya plagues my green key shoots.
Bill Davis May 1st, 2008 11:49 PM
Brian,
It's seldom that simple.
If you decide to do a luma key using BRIGHTER values (white), you can certainly pull a clean key - but what about the whites of the talent's eyes?
How about the white buttons on their shirt?
One of the reasons green is so popular for keys, is that there's very little pure green in skin tones and in its pretty easy to avoid in set dressing and costuming scenes. Even green eyes are typically more brownish hazel than the pure green of a chromakey.
The point of choosing green, or blue, or red or whatever is that the background key color represents a DIFFERENCE between what you want to key out and the stuff in the scene you need to maintain.
Modern software can help with garbage mattes - but you want to start by keying against a difference. And you'll quickly learn that a key light shining off a sweaty brow can read pretty close to a white backdrop - spoiling your clean key very quickly.
FWIW
Alex Humphrey May 21st, 2008 06:23 PM
The biggest film I worked on was TITANIC and we had lots of China balls, a few Keno's close to the actors, small battery single tube Keno's that were placed inside and behind beams, equipment and such just to fill in shadows where they wanted them. There were lots of reflectors for day shots, and zero or none for night. Night shots had lots of Keno or other flourscent blue lights to for fill. China balls at night for moon fill. And Various Mole's Baby's and Jr's, though I swear they were dimmed, and of course HMI for outside.
Honestly not much more than a lot of indies i've been on, except for the night , a lot more Keno's and china balls.... most importantly those little battery powered Keno (maybe other brand) that were used in practically every shot.
Now I've gotten away with for a music video for Linda Blair 8 Home Depot 500 watt Quartz shop lights with diffustions screen that worked very well. $5 light, + $12 light goose neck and $25 light stands, plust reflectors and cheap $15 umbrellas. Looked good enough. Hard to control, I wouldn't use it indoors, unless it was a large warehouse, but it got the job done for her quickly and cheaply. also don't forget the biggest thickest extension cords that you can. Thin ones trip breakers before thick ones.
So maybe a bunch of cheap Home Depot Shop lights with reflectors and diffusion screens might be the only way to do a decent job (with enough room) for $300.
Jim Andrada August 16th, 2008 10:58 PM
I asked a similar question a few months back and as I recall someone suggested using "Chinese Lanterns". As it turned out I didn't have to do it after all so I never tried it.
