Connecting gels and using barn doors on the Omni at DVinfo.net
Photon Management
Old August 18th, 2009, 04:57 PM   #1
I have a lowel Omni, with barn doors, and I am having problems connecting color gels to them while simultaneously having good use of the barn doors. Specifically, if I connect the gels to the barn doors using those "gel-jawz," I obviously can't move the barn doors without moving the gel. What would be the simplest way to connect the gels independently of the barn doors?
Natan Pakman is offline   Reply With Quote
Old August 18th, 2009, 05:59 PM   #2
Are you using one of these: Lowel | Tota-Frame for 10x12" Gels | T1-20 | B&H Photo Video
I can still use the barn doors with this gel frame attached.
Oren Arieli is offline   Reply With Quote
Old August 19th, 2009, 12:42 PM   #3
Yes, with the gel-frame I can use the barn doors, but it's a pretty clumsy set-up (if I want to move the barn doors in very tight, I have to move the gel-frame out of the way b/c it's so close to the light itself).
Additionally, the gel-frame connects to the Omni at the same spot you would connect a tota-brella. So let's say I want to use a gel and an umbrella. The only way I've been able to do this so far is to remove the top barn door and connect the gel to the other doors with clips, but the gel ends up very close to the light and therefore gets very hot (a few of my gels have burned quickly in this way).
Any ideas?
Old August 19th, 2009, 01:56 PM   #4
Clothespins
Use clothespins to attach the gel directly to the barn doors. Works great every time. Easily adjusted and low cost.
Mark Hendren, Mark Five Productions
www.markfiveproductions.com
Mark Hendren is offline   Reply With Quote
Old August 23rd, 2009, 09:03 PM   #5
Fact.
Really I think it's a matter of setting your barndoors and then throwing on your gel with C-47s.
Scott Lovejoy is offline   Reply With Quote
Old August 23rd, 2009, 09:43 PM   #6
It's bizzare. Everything else is so nicely engineered by Lowel. Those gell frames are exactly as you describe .. they interfere with the barndoors. The stem that holds them away from the fixture is not long enought. Period.
Old August 24th, 2009, 07:54 AM   #7
Les,
Exactly!
In any case, based on the comments I've seen here, and my own ideas, I assume the simplest solution is to use the gel frame to attach gels when leaving the barn doors completely open, and to use the c-47s or clothespins when angling the barn doors.
In terms of the umbrella and a gel, it seems like it's best to avoid its use with the Omni, b/c of the previously mentioned debacles.
Old August 24th, 2009, 10:15 AM   #8
Contributor
Use a full sheet of gel, clamp it on to the outer edges of the barn doors with C-47s and laet hit bulge out loosely, and you can move the barn doors however you want.
Old August 28th, 2009, 04:54 PM   #9
I never use the gel frames for lowel lights. We do what Mark said and C-47 the gels straight to the barn doors. Especially with omnis, you won't have any trouble with melting gels or anything like that, and you can adjust the barn doors as desired.
Jeff Kolada http://www.jeffkolada.com
Jeff Kolada is offline   Reply
