Neon Transformer at DVinfo.net
Photon Management
Old January 3rd, 2005, 10:42 AM   #1
Neon Transformer
For a short film, I need to dim a neon sign to simulate a short circuit.
Will I damage the transformer by using a standard household light dimmer on the AC to the transformer?
The dimming would only be for short blinks.
Thank you,
Douglas
Douglas Johnson is offline   Reply With Quote
Old January 3rd, 2005, 01:37 PM   #2
Air China Pilot
And I came to this thread expecting robots.
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old January 3rd, 2005, 08:57 PM   #3
Images: 1
Doug,
If you want to do this, buy the dimmer that is meant for inductive rather than resistive loads. A neon sign as you stated, uses a step up transformer and is therefore a coil which is an inductive load as opposed to a regular lamp filament which is a resistive load.
You would be more likely to burn up the dimmer unit if you used the wrong one.
Be careful. Let us know how it works out.
=gb=
Old January 3rd, 2005, 10:23 PM   #4
NEON TRANSFORMER
Dear Greg:
Thanks so much. Will search out the correct dimmer.
Regards,
Douglas
