New Comer CM-LED5500K Broadcasting and Studio LED Panel Light at DVinfo.net
Photon Management
Old March 21st, 2011, 10:19 AM   #1
Comer launches the new Comer CM-LED5500K broadcasting and studio LED Light. With it's high power output at 5500 lux and high portability, it is suitable for on-site shooting and field studio setup. The VARIABLE color temperate range from 3200K to 5600K makes CM-LBPS5500 very flexible to light scenes both indoor and outdoor.
- High illuminance with 5500 lux at 1 meter.
- Wide dispersion spread at 60 degree spot light
- Runs on battery or AC adapter
- Infra-red wireless remote control to adjust power on/off, brightness and variable color temperature
- Accepts Sony style V-mount Li-ion battery such as BP-C910S battery. The battery interface can also be replaced to accept Anton Bauer battery connection.
- Ultra-efficient: draws only 75W maximum power with luminous efficiency equivalent to 500W tungsten light.
- Includes powerful magnet snap-on white diffuser for wider spread illumination
- Briefcase style carrying case included with compartment to hold the CM-LBPS5500 light, filter, remote control, and one battery.
For more information, please visit Comer CM-LED5500K Broadcasting and Studio LED Light | L.A. Color Online
New Comer CM-LED5500K Broadcasting and Studio LED Panel Light-color-temp1.jpg   New Comer CM-LED5500K Broadcasting and Studio LED Panel Light-cm5500.jpg
New Comer CM-LED5500K Broadcasting and Studio LED Panel Light-nicolette2.jpg   New Comer CM-LED5500K Broadcasting and Studio LED Panel Light-beforeafter1.png
New Comer CM-LED5500K Broadcasting and Studio LED Panel Light-wedding1.jpg   New Comer CM-LED5500K Broadcasting and Studio LED Panel Light-wedding2.jpg
LA Color Pros Blog
Old March 22nd, 2011, 07:33 AM   #2
Re: New Comer CM-LED5500K Broadcasting and Studio LED Panel Light
Taky you never told me that these were now available. =)
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply With Quote
Old March 23rd, 2011, 12:00 PM   #3
ha! Yes Michael. They have been baking this product for a while. Now it is available. We will be showing them in NAB too. There're actually triplets.
CM-LED5500K - variable color temperature
CM-LED5500/56 - 5600K only
CM-LED5500/32 - 3200K only
LA Color Pros Blog
Old March 24th, 2011, 11:27 PM   #4
This is a comparison video of 4 LED lights, they are
- Comer CM-LED5500K
- Comer CM-LBPS1800
- Comer CM-LBPS900
- and another leading brand LED light
LA Color Pros Blog
Old March 28th, 2011, 07:12 PM   #5
3-Point Lighting with using 3 Comer CM-LED5500K
LA Color Pros Blog
Old March 29th, 2011, 01:00 AM   #6
Some form of indication of what CT the light is ouputting would be a handy feature or have I missed something.
Old March 29th, 2011, 02:19 AM   #7
Hi Bob
Ahem ... Reading the first post in detail and following the link within the first post would let you find out that it has a variable color temperatur from 3200K to 5600K
Cheers
Peter
Peter Arnold is offline   Reply With Quote
Old March 29th, 2011, 04:34 AM   #8
I was all excited until I saw the price. How does this light compare to a 600 LED?
Old March 29th, 2011, 09:44 AM   #9
Bob, it has a variable color temperature range from 3200K to 5600K.
LA Color Pros Blog
Old March 29th, 2011, 09:54 AM   #10
It's the flexibility of this light makes it better. Compare to the other LED light, it is not just 3200K or 5600K color temperature. It's variable anything in between 3200K to 5600K. You also do not have to determine whether if you need spot or flood light before you purchase the light. You want your investment to be used in all circumstances.
We are Comer authorized dealer in the United States. We ship products directly from the US. Any warranty service is taken care domestically too.
LA Color Pros Blog
Old March 29th, 2011, 04:37 PM   #11
Yes,hence my question. How do we know WHAT CT it is outputting?
By comparison Zylights products have readouts that state the CT as you vary it.
Old March 29th, 2011, 07:22 PM   #12
There're 3 pre-set color temperature at 3200K, 4500K and 5600K. For the variable color temperature values in between, there isn't a display to show.
LA Color Pros Blog
Old March 31st, 2011, 09:45 PM   #13
Demonstrating Comer CM-LED5500K Illumination and Color Temperature
LA Color Pros Blog
Old April 1st, 2011, 10:59 AM   #14
Taky will the color temp change as you dim the light?
I only ask, becasue the poor girl is being blown away when you switch the light to 5500k while outdoors, and wonder if the color temp will change as you dim down the light.
Michael
www.lvpvideo.com
Old April 5th, 2011, 01:49 AM   #15
Michael, the light has separate controls on brightness and color temperature. Adjusting the dimmer won't change the color temperature.
LA Color Pros Blog
Taky Cheung is offline   Reply
