5K Fresnel at DVinfo.net
Photon Management
Old August 15th, 2006, 08:34 AM   #1
5K Fresnel
Is anybody using one of these, if so, at around 40 amps how are you powering it? Thanks
Michael Best is offline   Reply With Quote
Old August 15th, 2006, 11:06 AM   #2
Hawaiian Shirt Mogul
usually with a generator ... or using power on a sound stage ...
or if allowed/legal a tie in to the electrical main box - then sub boxes with circuits that can handle 40amps ...
note: that it's all special electrical cable not the kind you get from home depot ...
Don Donatello is offline   Reply With Quote
Old August 15th, 2006, 11:25 AM   #3
good info thanks, I suppose there's no way to say 'couple' two 20 amp sockets on a generator?
Old August 15th, 2006, 11:48 AM   #4
i know it's been done ( depends on type generator) but don't know the how ...
call a lighting/generator rental house and ask them or ask a local gaffer in your area for the details ...
i've know that some gaffers will hook into a 220v electric dryer/stove plugs in houses with speacial plug-cable ...
Old August 15th, 2006, 04:34 PM   #5
Just an FYI Mole makes an adapter to use a 2k lamp in the 5k light.
#1921 5KW to 2KW Socket Adapter
If power availability prevents using a 5k lamp you can still use the light. Around $75 US.
Bill
Cinematographers Bring Shadow To Light
Bill Hamell is offline   Reply With Quote
Old August 16th, 2006, 10:24 AM   #6
We have 5K dimmers and 8 gauge wire with the big stage pin connectors.
Jacques Mersereau
University of Michigan-Video Studio Manager
Jacques Mersereau is offline   Reply With Quote
Old September 3rd, 2006, 11:09 AM   #7
I learned and tested something that would allow you to use 20amps (actually 16.6 amps) instead of 50amps (41.5)
A Arri 2K Fresnel will give you the same stop as a Mole Richardson 5k Fresnel.
The lens and reflector of the Arri are engineered to transmit the most amount of light from the lamp.
Or, I bet you could just use a 1200 HMI Par light instead of the 5K. Just add some CTO to make it 3200K. 1200 uses even less amps than a 2K tungsten Fresnel.
To capture an image, any camera needs a certain amount of illumination for proper exposure.
Then start taking light away.
Charles Hohenshilt is offline   Reply With Quote
Old September 7th, 2006, 10:17 AM   #8
Yeah, pay attention to that amp figure that Charles mentioned for the 5K. Trying to power a 5K off of two 20 amp circuits will not work well :)
Around here, the common termination on a 5KW unit is a 60amp Bates cable.
Ralph Keyser is offline   Reply
