-   Shoulder & Handheld Supports (https://www.dvinfo.net/forum/shoulder-handheld-supports/)
-   -   shock absorbing arm for (https://www.dvinfo.net/forum/shoulder-handheld-supports/122085-shock-absorbing-arm.html)
Stephen Eastwood May 21st, 2008 02:09 AM
the steadistick/spider brace?
I have a steadistick and a spiderbrace, I like the spiderbrace and would love to mount the steadistick to it on the bottom so it holds the weight while allowing the control of the shoulder mount, I never got great at fine control of the steadistick in movements.
My issue is before I adapt it all, I would really prefer to change the steadistick arm while just locks at a position to an arm that works more like a shock absorber with a lock down. That makes far more sense than a locked position arm.
It would be fine if I lose the quick release aspect of the top of the steadistick, in fact I am thinking of mounting a quick release plate the bottom of the spiderbrace and a receiver on the steadistick so I can slide it on and off the steadistic with that and when of slide it on a tripod on the brace.
All that to ask is there a shock absorbing arm that I can put in place of the steadistick arm available anywhere?
Les Wilson September 27th, 2008 03:20 PM
I've come to the same conclusion with the Spiderbrace. The DVRIG claims it's shock absorbing but none of the videos show it doing moves other than locked up and the operator moving it around the holster base. The DVCaddie has a parallelogram but again, no compression. Ditto Steady Stick. Did you find a shock absorbing arm?
FOLLOWUP: I found the answer. DVTec pod is shock absorbing. It's custom made and according to the information I found, travels about 40cm. Adam Wilt used it to film Maelstrom using an EX1.
