A Small Tip re: Varizoom Shoulder Support at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old September 19th, 2002, 10:59 PM   #1
Retired DV Info Net Almunus
For those of you using, or considering, Varizoom's VZ-LSP or VZ-1 shoulder braces you should consider adding a Bogen/Manfrotto quick-release mounting plate to these rigs. Since these braces do not feature a quick-release mount the Bogen q-r plate is an invaluable addition to these rigs, making it much easier to remove the camera for tight hand shots or just to be able to detach the brace to safely set the camera down.
Honestly, with the relatively high prices of these low-tech braces I was disappointed that they do not feature a quick-release plate.
Ken Tanaka is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
