Question about the Mini Rover at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old March 7th, 2005, 04:11 PM   #1
I really want to buy the Mini Rover for my GL2 to use as a support for handheld shots and to hold a mic, but I'm curious as to how the Mini-Mate works with it. The Mini-Mate would be great to hold a wireless mic receiver also, but from the pictures, it seems like it covers up the hot shoe on the Mini Rover, preventing you from using a shotgun mic on the Mini Rover and a wireless receiver on the Mini Mate at the same time.
Does anyone know for sure, if you can use this setup to hold both a wireless receiver and shotgun mic at the same time?
Also, if I were to use the Mini Mate, it appears that it would mount the receiver horizontally, instead of vertically. I thought I had read somewhere that radio mics should be mounted vertically to get the best pickup? Is that correct?
www.interactiverecipes.com
Chris Wright is offline   Reply With Quote
Old March 10th, 2005, 05:21 PM   #2
anyone?
Old March 13th, 2005, 07:30 AM   #3
Still Motion
Chris, I can't answer you specific question but I can say that I looked at the products your mentioning and deciding to buy a still camera flash bracket from B&H. To me, it does the same job, and my flash bracket was about $10. I have it hooked up to hold a shotgun and a wireless mic.
Not sure if that helps but it is worth looking at.
Patrick Moreau is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
