Question for Danny Natovich on DVRigPro at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old March 24th, 2005, 12:15 PM   #1
"The new DvRigPro's back part was modified and is now about 2
Kg Lighter. The support belt is wider and paded, The pod's holster
is detachble and deeper. and the support pod has two locks."
Danny I just purchased a DVRig from BHPhoto a few weeks ago, and it has 2 locks on the support pod.
Do I have the new one, or did the old rig have 2 locks on the pod?
Also what is the purpose of having 2 locks on the pod as opposed to only one. I was trying to figure this out as I was trying to practice moving with it.
Michael
LVProductions
Michael Liebergot is offline   Reply With Quote
Old March 24th, 2005, 03:23 PM   #2
DV Rig Pro
With the two locks pod you can extend the pod and lock it at a higher position then before.
It is recommended to use the top lock to fix the camera height and leave the bottom one unlocked.
The bottom spring is harder then the top one, Use the one that is best for you. Notice that leaving both springs active, Both locks un locked, Can cause a small jerks in the pods movment.
Danny.
Danny Natovich is offline   Reply With Quote
Old March 25th, 2005, 09:32 AM   #3
Danny, thanks for the answer to the pod.
But I was also curious as if I have the new DVRigPro that I purchased last month from B&H. As I said it does have the double lock pod.
Thanks again,
Michael
LVProductions
Old March 25th, 2005, 10:37 AM   #4
DV Rig Pro
Have a look at the front page www.dvtec.tv
The new have a blue light shoulder brace.
Old March 25th, 2005, 11:17 AM   #5
Well I guess I have the old one as the shoulder brace is Black/not Blue and the waist belt is Red/not Blue.
I thought I might have teh new one because in a previous post it was mentioned that the new one had a double lock on the pod.
BTW Danny, is there any way that I would be able to get the new Waist belt. The deeper pocket would be a welcome addition.
Thanks, I love the product anyway.
Michael
LVProductions
Old March 29th, 2005, 08:38 PM   #6
DV Rig Pro
Does anyone know where I can see a DV Rig Pro in NYC? I went to B+H but they don't have it on display and wouldn't take one out of the box...
I'd love to at look at one in real life before I get it.
Thanks to all who reply.
Marc Singer is offline   Reply With Quote
Old March 30th, 2005, 02:26 AM   #7
DV Rig Pro
Call Varizoom (888) 826-3399 they will direct you.
Or try one at NAB.
Danny.
Old March 30th, 2005, 05:12 PM   #8
XL and DVX
I got both Canons and DVX cameras that I will be using could i use the dvrigpro with the XL? I would hate to have to buy two versions.
Also will i have a problem mounting my rods w/mattebox on the rig? for the DVX
Gregory Doi is offline   Reply With Quote
Old March 31st, 2005, 12:17 AM   #9
DV Rig Pro
It is not recomanded to use the XL on a DvRigPro. you can however save by purchasing only a front DvRigXL (Half the cost)
and use it with the DvRigPro back part (Shoulder brace).
The back part, the support pod and belt are the same for the two models.
Danny.
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
