Multirig Pro or DvRigPro for Canon A1
Multirig Pro or DvRigPro for Canon A1 with Canon wd converter? Alltogether (plus the BP970 battery) the camera weights quite a lot.
And i like the "shock absorbing support pod" of the DVrigPro. Does the Multirig also have it? Thanks |
Bruce, I'm considering the Multirig pro for a Brevis mounted HVX setup. Total weight 9lb and centre balanced (on rails). The DVRig HD Pro is designed for this setup, but the versatility of the Multirig has me interested. Do you think the the Multirig could handle such an application? How about the stabiliser plus config (out in front)? If you feel your opinion unqualified I'm still interested to hear you thoughts. Thanks.
Steve,
When I use it with my XLH1, I basically use the spring loaded podand move the handles out of the way.The pod supports the camera, and i keep both of my hands on the camera, not the handles. I keep the H1 in shoulder mount with my eye to the eyepiece. With a lighter camera, the other positions are possible, but with the weight and size of my loaded H1, I only use the one position.I'm sure some people use the same cam in other positions, but I like having my hands on the camera itself. If I had to stand in one position, on the other hand,then I might want to use the stabilizer plus set up using the lcd instead of the eye view finder. Bruce S. Yarock www.yarock.com |
Bruce that multirig is certainly a slick looking unit. A lot of thought went in to that design. When using with XL series you are basically ignoring all three of the extension handles and just using the support stick. Is that right? Or do you have one of the handles over your shoulder? I'm sold on DVTEC but can't decide on which unit. I use XL series mostly but also some of the smaller cams. would love to have a rig that supports both styles of camera. The DVrig XL looks like it places the shoulder support too far behind the camera for my style, but I do like the way the pod supports the camera further forward than the tripod connect location. Any comments?
" When using with XL series you are basically ignoring all three of the extension handles and just using the support stick. Is that right? "
Yes. That's the only way I use it. "Or do you have one of the handles over your shoulder? " No. "I'm sold on DVTEC but can't decide on which unit. I use XL series mostly but also some of the smaller cams. would love to have a rig that supports both styles of camera" The multirig would be more versatile with a smaller rig. I also have a SonyFX1. and have been able to use it briefly in stabilizer plus. "The DVrig XL looks like it places the shoulder support too far behind the camera for my style, but I do like the way the pod supports the camera further forward than the tripod connect location. Any comments? " I use a manfrotto plate and leave it on the Multi. That way I can slide the H1 forward or backwards for balancing. Bruce S. Yarock www.yarock.com |
I don't leave the multirig permanently attached to the camera. If I want to use the tripod, I slide the camera off of the MR and on to the tripod. I have the same manfrotto set up on two tripods and a monopod. And each camera has the matching plate that slides in the manfrotto (I think it's the #577).
so basically with the xl style cams you aren't really using the multirig just the support stick, So the JR model would be just as good?
I don't know that model. You could use the handels, but I feel more secure with my hands on the camera.
Bruce S. yarock www.yarock.com |
no I have not seen the JR either. Basically it is just the stick and belt, which I guess is really all you are using
Great info Bruce.
I shot a 5 hour concert with the stock HVX on the MR Pro with no problems, and today had the Brevis/HVX setup on the rig too. The adjustability of the MR Pro is a huge plus. I wonder if there's a cam or cam/35mm adapter setup that this baby couldn't handle. |
Steve, would you mind to share your 'Brevis/HVX setup on the rig' pictures? Thanks in advance
Will do Ian...end of week I'll have the time.
Here's a couple of photos and a clip from my quick shoot this afternoon.
www.conceptsmith.com.au/bmr1.jpg www.conceptsmith.com.au/bmr2.jpg www.conceptsmith.com.au/bmr3.jpg www.conceptsmith.com.au/bmr.wmv I tried to be clever and switch focus midshot - certainly doable without a follow focus unit but very hard to be precise and hard to keep the camera steady (it's a long reach to the front of the cam). This was my 1st shoot with this setup so I'm sure I'll improve. In future, at very the least I'll remember which way to turn the focus ring :) |
Wow, thanks Steve! Yes I second that setup would be better with a follow focus. Is your setup well balanced (looks like it's front-heavy)? I'm going to post my pics soon after I get the Canon HV20, currently out of stock in my country:( Btw, nice setup!
| All times are GMT -6. The time now is 02:02 AM. |
