Care when changing out the C: drive card. at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old April 3rd, 2009, 10:17 PM   #1
If you get careless, go where you shouldn't go and mess up the operating system, don't have a recovery USB key and instead replace the corrupted C: drive card with a backup, be aware that a little screw which you remove to allow the card to be withrawn, passes through a concealed tiny black pillar washer or sleeve which rests between the circuit board and support frame.
If this little washer or sleeve slips out when you remove the screw and you later re-insert the screw and tighten down with the black washer missing, you will bend and may damage the circuit board.
Bob Hart is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
