IR with SI2K at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old October 20th, 2012, 03:19 AM   #1
IR with SI2K
Most who own or operate this camera system know it can do infra-red if the IR/OPLF panel is removed from the optical path and visible wavelength light filtered out. SI has also made custom versions for IR.
With the longer wavelength of IR light and the optical effect of the IR/OLPF missing from the optical path, considerable adjustment of the lens flange face rearwards may be required for focal performance to be re-established.
Bob Hart is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
