NEW Digital Cinema Camera - Operational and showing at NAB - Page 2 at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old April 18th, 2006, 10:05 AM   #16
Who would even want a F950 anymore?
While the F950 may have a few video camera type things that make it a better camera when it comes to workflow and storage and price this camera really does blow it away.
HDCAM SR and uncompressed are a bear to deal with while Cineform is not only small enough to fit on single hard drives but is easier on the cpu than mpeg2 based formats. While uncompressed RGB may be slightly better than Cineform RAW it is much much closer than HDV or DVCPRO HD would ever be.
My only concern at this point would be color in low light and just low light performance is general. It is after all a single chip camera. I know single chips can be great for film production where you have lots of light but what if you don't have lots of light?
I can really see other people using this camera for live HDTV work since it can record up to 4 hours. It would be much higher quality than HDV but not nearly as expensive as HDCAM SR. I happen to know a few guys who do just weddings that are planning on getting the SONY 350 in a few months. If they are willing to spend that much on a camera to get slightly better than HDV quality at 1/2" then why not go 2/3" with this great camera?
How well would the camera work in a live situation?
Old April 18th, 2006, 10:45 AM   #17
Silicon Imaging, Inc.
Another clarification
Just to be clear since there was some confusion in a Tom's Hardware article, the battery life is something like 1-1.5Hrs per battery. The disk storage is 4 hours per drive.
Regards,
Steve
...snip....
We see the Light!
http://www.siliconimaging.com
Steve Nordhauser is offline   Reply With Quote
Old April 18th, 2006, 11:47 AM   #18
Not to start up a hardware war, or anything, but this cam is much more realistic for a 20k price tag than the RED camera. I know a lot of people are hoping that RED is going to come in at 20k, but I just don't see it. This is definately going to hit the "sweet spot" for indie filmmakers.
Glenn Gipson is offline   Reply With Quote
Old April 18th, 2006, 12:02 PM   #19
RED Code Chef
Hi Steve & David, that's some good news!
Originally Posted by Steve Nordhauser
Yes. The pricing for a camera head system, which includes the SI-1920HD-GE camera head, a copy of Prospect HD Edit, Premiere Pro 2.0, a Arri-base-plate adapter, and two Fujinon c-mount lenses will retail for $12,500.
Just hypothetical, but what if someone already has Premiere Pro 2.0 and c-mount
lenses for example?
Rob Lohman, visuar@iname.com
Old April 18th, 2006, 12:17 PM   #20
We'll know after NAB :-D
Mathieu Ghekiere is offline   Reply With Quote
Old April 18th, 2006, 01:15 PM   #21
under the dept 'this sounds really cool but...'
What dispaly technology is out there that will let us preview 10bit video during the editing process? I know ATI and nVidia have 10bit ramdac chips but this sounds like you will need a high end sdi capable CRT to get full color and contrast.
Should that be figured into the cost?
Boycott Guinness, bring back the pint!!!
Joe Carney is offline   Reply With Quote
Old April 18th, 2006, 01:37 PM   #22
Wow - this does look pretty promising. If the noise can be smoothed out a bit more it would be great. The DOF at at 1.4 looks pretty good to me. This is worth keeping a close eye on and might even inspire Redto to drop their pricing a little if needed.
Joel Aaron is offline   Reply With Quote
Old April 18th, 2006, 01:45 PM   #23
CTO, CineForm Inc.
Joe, AJA Xena LH or LHe is the way to go for monitoring. However a 10-bit display as you describe is not necessary. Remember 10-bit adds levels between the 8-bit levels, designed for color correction without contouring.
Old April 18th, 2006, 04:18 PM   #24
lenses for example?
I'd like to know as well - that was just what I was thinking...
PPro is around $850..
also did they say which C-mount lenses are free?
Edited to remove pricing subtractions :)
Ram Ganesh is offline   Reply With Quote
Old April 18th, 2006, 04:27 PM   #25
CTO, CineForm Inc.
Pricing speculation like this should not be put on the forum when you can simply ask Silicon Imaging. Doing subtractions of retail prices makes no sense.
Old April 18th, 2006, 10:00 PM   #26
Ram Ganesh just got OWNED by David Newman! no, im just kidding. it's pretty funny though.
Forrest Schultz is offline   Reply With Quote
Old April 19th, 2006, 03:47 AM   #27
Im impressed, this is the approach i would take if i found myself designing a camera. On paper it looks very exciting.
Price is good too, $20k plus another $10k worth of lenses and bits i would imagine.
I wonder how robust the camera is on location... physical dimensions, weights etc would be useful.
David, the cineform RAW codec states 10bit but i can't find anywhere whether that's 10bit log or linear? Obviously i hope it's log... If the head does 12bit then log would be the best way to capture that? I'd hate to loose those 2 bits by having to determine at the capture stage what i needed - to have the dSLR raw workflow for film is perfect for me.
The sample images/movies really aren't that good though, if i was SI i would consider pulling the footage or getting better full res stills before showing the world. It would also be worth stating what lenses were used as they would be the determining factor with quality and DOF.
I assume that up to 70fps is only 720p, how fast can 1080p go, just to 30?
One other area not discussed yet is timelines, i would love to get a ballpark as to when the system could be demo'd/purchased.
Sadly no NAB for me this year, so i will have to virtually visit via the internet.
cheers, paul
Paul Curtis is offline   Reply With Quote
Old April 19th, 2006, 05:18 AM   #28
Hi Paul,
I work with David, Steve, and Jason, and know a bit about the camera.
The 10-bit Cineform signal is log, standard dynamic range or wide dynamic range (both log curves). With the black pedestal settings, you are getting the *absolute* best 10-bits from the 12-bit sensor
30 fps should be 1080p.
cheers,
Kyle
Kyle Granger is offline   Reply With Quote
Old April 19th, 2006, 05:21 AM   #29
Paul,
A lot of good questions there. We run the sensor acquisition at 12 bit linear and the Cineform codec is 10 bit log.
The physical dimensions and weight are on the spec sheet at our web site:
12"x4"x8" and 13lbs.
We decided to wait on photos of the camera until after NAB to stir things up a bit. We put up what footage we had to convince people that this is a real camera. There will be much more very soon. We are taking part in the CML party to get some pro footage and more feedback on the camera. There are also a few early units going to filmmakers. They will be posting some dailies on our support forum at the web site.
1080p at up to 30fps, 720p at up to 72fps. We run the 1080p at 2x the rate in the camera head and drop every other frame. This cuts any rolling shutter artifacts in half while keeping the bandwidth low.
Full production is Q3 2006. This is mainly a sensor availability issue.
Regards,
Steve
We see the Light!
Old April 19th, 2006, 05:39 AM   #30
like Steve said.... ;-)
Plus additional vertical blanking, higher pixel clock, further reducing any rolling shutter Useful for 24p.
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
