When will the mini be available? - Page 2 at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old September 5th, 2006, 09:57 AM   #16
Originally Posted by Jason Rodriguez
The Polecam should be easy to adapt to . . . simply run the head from the Polecam with gig-e to a recording box that you can sling over your shoulder like an audio recorder . . . that way you don't end up with a lot of weight on the end of the pole (the small heads are really light, like around 1lbs.)
The recording box can be really small too . . . like using a Mini-ITX with Merom or something of that nature.
A laptop could work nicely as well, although I'm not sure if there are issues when you close the lid on the laptop with it going to sleep.
take a look at this little gem coming from Acer
http://global.acer.com/products/tablet_pc/tmc210.htm#01
A tablet pc w/Merom processor, option for second battery instead of optical drive for up to 8 hrs of use. 4 gig of ram, 12.1 inch screen. on board gigEthernet....
Boycott Guinness, bring back the pint!!!
Joe Carney is offline   Reply With Quote
Old September 7th, 2006, 10:14 AM   #17
Did I upset someone? Just checking.
Old September 7th, 2006, 10:56 AM   #18
Nope . . . that does look like a very nice tablet PC . . . I can think of some nifty rigs you could put together with one of those like that.
Jason Rodriguez is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
