Re: PXW-X70 Frimware v2.0 is released!
The JVC HM200 is now $2495, making it $4 cheaper than the Sony x70 with paid firmware upgrade (assuming it's $500). http://www.bhphotovideo.com/c/product/1096582-REG/jvc_gy_hm200_gy_hm220_4kcam_streaming_camcorder.html |
In the end it will be a real shoulder , a cell phone for fun and handy things and a gh4 or red/arri for movies (with a script, actors, a crew, a director). those handy-gadgets and all the frankenrigs will soon be a thing of the (absurd) past. |
Is anyone having this problem? If I record both AVCHD and XAVC onto the same card, FCPX v10.2.0 can only see the AVCHD footage. So if this really is happening, don't record mixed codecs on the same unformatted card!
I just shot one 720 XAVC story, ingested, fed it in to my station, then popped the card out, back into the camera, shot another 720 XAVC story, but when I popped the card back into the Mac, FCP X would only load the PREVIOUS story clips. I ejected the card and reinserted it several times, but could not get the new files to show. Had to shut down FCP X and restart it, then they loaded. Very quirky.
Paul |
I just noticed the header on this thread says Frimware.....hehe. :-)
Paul |
I had real problems using FCPX 10.2.0 sometimes XAVC could be seen, sometimes not. upgraded to 10.2.1 and working fine. I tried mixed codecs on the same card- AVCHD and XAVC. FCPX 10.2.1 can only 'see' the AVCHD files, the XAVC files appear only as JPEGS and audio. So don't mix codecs , only one type per card.
Finally, with the new firmware and FCP X update, I can shoot the same XAVC-L codec on all my cameras.
XAVC looks SOOOOO much better than AVCHD. Colors pop, everything is crisper. All my footage gets exported out as HDV 720p60 18Mbps, and AVCHD just comes out the other end as mush, soft, fuzzy, colorless. Better quality in, better quality out. Paul |
Shot my first wedding with XAVC-L 50mbps at the weekend & used native FCPX ingest. I've not had such unreliable footage since FCP5 & HDV.
I will say though that the footage is gorgeous & you can notice the extra colour depth compared to AVCHD, however.... 1) FCPX can only seem to cope with 2 multicam streams of XAVC-L on my iMac (3.4 i7, 24gb, GTX680MX), 3+ streams drops it down to 2-3 fps, so I'm having to use proxy files. 2) Getting occasional 'glitches' (Blocking) on some clips - it's not on the original file, but appears on particular clips at random points at random times in both the FCPX viewer AND THE EXPORTED FILE - I'll have to find a work around (hopefully transcoding to 'optimised' will sort it). http://i60.tinypic.com/wl9hk4.jpg 3) Went to export a 'guest messages' extra scene & the video freeze frames both in the timeline & on the exported file - the audio still runs but the video freezes for the rest of that individual clip. tried using an 'transcode to optimised' Pro-Res transcode & the same thing happened. My work around was to export each individual clip as a basic h.264 file & re-import - annoying! So for me, native XAVC-L in FCPX is not reliable enough & is more hassle than it's worth at the moment because if I need to transcode the footage to Pro-Res for it to work properly in FCPX, I may as well just use Edit-Ready anyway..... damn you Sony & Apple! |
Tomorrow arrive to me 4K license, after activating (sony web process, I don't know if this be asap) in camera I can send some 4K footage from X70.
Paul,
What sort of drive are you working from for your editing? I'm just thinking that maybe that is a performance bottleneck and not necessarily the CPU, or the footage itself? |
The Multicam fps I can deal with by using Proxy - that's not a big deal & half to be expected, however I'm more worried by the glitches on export with native XAVC-L (fixed by transcoding to Pro-Res) & the clips 'freeze framing' - both of these are with a single stream of 50Mbps video, which IIRC is only 6MBps giving me 100+MBps headroom |
WTH do I get this CBKZ-X70FX 4K option? It's like Sony doesn't want us to find it. A few posts up, someone else already ordered it.
I only want it because I can't have it. :( Paul |
The most disappointing thing for me is that Sony haven\'t fixed their wacky colours. Paul\'s excellent settings sort of patch over the problems but I have an RX10 and an FS700 that perform much better out of the box. Come on Sony - how could you get it so wrong? The lack of a log profile and charging a 25% premium for a 4k " key" seems ridiculous esp as they are still protecting their premium products by limiting the data rate to 60Mbs which is lower than than the new fdr-ax100 data ratemb
I must be blind. I located the USA 2.0 but where the heck is the purchase area for the 4K unlock code?
| All times are GMT -6. The time now is 01:31 PM. |
