60Mbp/s vs. 100Mbps - Supprising Video Samples - Page 3 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old June 12th, 2015, 11:11 AM   #31
Re: 60Mbp/s vs. 100Mbps - Supprising Video Samples
Now panning 2160 in 30p shutter 1/50
https://ssl.unlp.sk/x70/Clip0100.MXF
https://ssl.unlp.sk/x70/Clip0098.MXF
btw. new vegas out
Notable fixes/changes version 13.0 (Build 453)
-Fixed a bug that could cause the application to crash when using the Median or Min and Max video effects with an NVIDIA GPU.
-Fixed an issue that prevented Vegas Pro 13 from importing XAVC-L files recorded by the PXW-X70 camera.
-Fixed a bug that prevented XAVC long-GOP files rendered by Vegas Pro from playing on the PXW-X180 camera.
-Fixed an issue that caused the Wave Hammer Surround plug-in to run in Demo mode. The plug-in is now enabled in Vegas Pro.
-Improved playback performance for some MP4 video clips recorded by GoPro Hero cameras.
Zenes Petrusin is offline   Reply With Quote
Old June 12th, 2015, 01:49 PM   #32
Much better panning in 30p, but only with VLC. Vegas still slow and jerky.
Old June 12th, 2015, 01:59 PM   #33
I think in Vegas again is problem with accelerating this 4k xavc. Try Sony Catalyst Browse if problem too.
Old June 17th, 2015, 03:45 AM   #34
@ Zenes: Could you upload the complete folder from the SDXC-card to test the function with Final Cut Pro X, but only the mxf isn`t recognized by FCP X, who needs the complete card-folder, so the testfiles only readable by Catalyst Browse. Thank you.
Eric Deyerler is offline   Reply With Quote
Old June 17th, 2015, 09:43 AM   #35
Four more 4k clips from X70 in directory structure
https://ssl.unlp.sk/x70/PRIVATE.ZIP (640MB)
Old June 17th, 2015, 12:29 PM   #36
Beautiful - were is the lake in Czech?
Old June 17th, 2015, 12:50 PM   #37
this is in Slovakia, High Tatras, Strbske pleso
Old June 17th, 2015, 02:38 PM   #38
I thought at first time tatra, because I read you are in Czech. It is a nice place there!
Old June 17th, 2015, 04:43 PM   #39
60Mbps vs 100Mbps on the AX100.
It's subtle, and it surprised me, but it's there. The 100mbps shows less aftifacting, macroblocking and smearing, in the darks especially. I pushed these images pretty far with by brightening up the mids considerably and adding a pretty intense LUT. Please note that I didn't try to make the images look good, but instead tried to show the differences in the bitrate by grading it intensely. See what I mean by looking at the brown box in shadow underneath the case on the shelf.
FWIW screen grabs attached. (can't attach the 100mbps wide for some reason, but you can see the differences in the CU)
60Mbp/s  vs. 100Mbps - Supprising Video Samples-60mbps.jpg   60Mbp/s  vs. 100Mbps - Supprising Video Samples-60mbps-cu.jpg
60Mbp/s  vs. 100Mbps - Supprising Video Samples-100mbps-cu.jpg
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old June 19th, 2015, 03:14 PM   #40
So, I'm still not sure that the teeny weeny difference in quality is worth the doubling in file size going to 100mbps?
Andy Smith is offline   Reply With Quote
Old June 20th, 2015, 12:21 AM   #41
I completely agree - unless of course your intention is to zoom in on your video by 500% :-)
Paul Hardy is offline   Reply With Quote
Old June 20th, 2015, 06:04 AM   #42
Go Cycle
Less artifacting when panning........I see it in the 100 Mps
Lou Bruno
Lou Bruno is offline   Reply With Quote
Old December 6th, 2021, 10:09 PM   #43
Anyone have access to these files? I need to download them
*Edit* no longer needed
Fabian Charlton is offline   Reply
