-   Sony 4K Ultra HD Handhelds (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/)
-   -   X70 streaming thumbnail (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/529641-x70-streaming-thumbnail.html)
James E. Thomas September 5th, 2015 11:15 AM
I can setup streaming on my X70 just fine until I reach the point that tells me to press the streaming thumbnail to start streaming, The thumbnail is not active and does nothing no matter what I do. Has anyone experienced this or have any ideas?
Craig Seeman September 7th, 2015 12:28 PM
Re: X70 streaming thumbnail
It's not clear you've set streaming up correctly.
Have you setup and confirmed WiFi works?
I'm not quite sure what you mean by "thumbnail is not active." It's a hardware button one pushes.
James E. Thomas September 7th, 2015 03:11 PM
Thanks Craig, I do have my wifI connection setup correctly and when I execute the preset I get the ( Streaming ) on the LCD screen. I am trying to stream to VLC Player and am entering udp://@:1234 for a network URL but I never get the stream in VLC. At the bottom of the LCD I have ( thumbnail ) start stream, I don't know if I am streaming and just not have VLC setup correctly or I still need to do something to start the stream?
Craig Seeman September 7th, 2015 03:25 PM
It looks like you have it setup correctly. Make sure you hit that thumbnail button. But I use udp://:1234 (no @) and it works.
James E. Thomas September 7th, 2015 05:07 PM
I hate to admit it I I was totally unaware of the thumbnail button, also don't know where I came up with the ( @ ). It's working fine now, I really appreciate the help,
Paul Anderegg September 8th, 2015 05:53 PM
The thumbnail button only activates streaming start, after you activate streaming operation mode, which would need a second button assigned. You will see blue text saying thumbnail to start streaming across the bottom of the screen after pressing the streaming operation button, which will first open a select WiFi screen.
Paul
Donald McPherson November 27th, 2015 02:09 PM
Almost got it working with screen stream for android. Forget about the content as it's just a trial.
