X70 to android VLC How to at DVinfo.net
Sony 4K Ultra HD Handhelds
Old January 7th, 2016, 03:55 PM   #1
This is how I got VLC to work on my android phone.
Go to settings
More
Tethering &portable hotspots
Portable wifi hotspots: select
I used an app called "Wifi access point to find my ip: 192.168.43.1 yours may be different.
PXW-X70
Settings
Wifi set
Access point
Select your camera stream
Then go to streaming
I used preset 2
Size (I'm trying) 640 × 360
Destination (mine) 192.168.43.1 (guessing yours will be different.)
Port 1234
Execute
Wifi
Back to android. Have you downloaded VLC yet?
VLC
Open ML
Enter udp://:1234
Back to camera
Press thumbnail hopefully you'll see the video in VLC
I STILL NEED HELP WITH "Screen Streem" app that I put on my phone.
Maybe someone else can figure this out. I've nearly got it but I'm on limited 4G.
Discovered how it wouldn't show up in YouTube this time.
Received an email for copyright infringement. That'll teach me to point at TV while I practice.
Donald McPherson is offline   Reply With Quote
Old January 14th, 2016, 04:04 AM   #2
Re: X70 to android VLC How to
Hi Donald,
thanks for your post. I experience a terrible delay on my phone, about 1.5-2 seconds. That makes it pretty much useless. Do you have the same problem? Also, after about 1-2 minutes VLC crashes. Could be my old phone running on Android 4.1.1. Any ideas on that?
Best, Toby
Tobias Meinken is offline   Reply With Quote
Old January 15th, 2016, 07:56 AM   #3
1-2 second delay on MPEG-TS UDP streaming is quite normal. I stream to a Teradek receiver over 4G to my station every night,and that is about what we get through the internet.
Paul
Old January 15th, 2016, 11:59 AM   #4
My phone's Sony Xperia Z3 running android 5.1.1 works long enough for me. Still need to sort out this livestream to youtube. I wish I could do it over the wifi instead of 4G as I only have 500mb and don't want to wast them. And yes around 1 to 2 seconds lag.
Old January 16th, 2016, 02:45 AM   #5
Do you think, the delay would decrease if streaming through a wifi connection? I saw a gadget on ebay the other day, which connects analog to the camera and streams live footage via an own established wifi channel. There's an app for the mobile, which displays the stream (I think, it's intended use is for reverse cameras in cars). That would add a piece of gear plus power source on the camera side, but you could have a quick, cable-free and small/lightweight solution for a second field monitor.
Toby
Old April 10th, 2016, 12:18 PM   #6
Finaly got it working. But it eats up my 4G.
