Pxw-x70 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old January 30th, 2016, 07:28 AM   #1
Pxw-x70
Hi there.
Unfortunately I found out that my X70 screws up and down for audio recordings, can this be switched off?
Kind Regards
Bjarne E. Nielsen
Bjarne E Nielen is offline   Reply With Quote
Old January 30th, 2016, 11:21 PM   #2
Re: Pxw-x70
I believe by "screws" you mean it increases and decreases AUTOMATICALLY? If you are using an XLR microphone, you should ensure that your handle switch controls are not set to AUTO. Set them to MAN and adjust your audio dials on the handle.
If you are using the BUILT IN microphone, no XLR attached, then the audio AUTOMATIC vs MANUAL controls for audio level are in the audio menu.
Paul
Old January 31st, 2016, 04:29 AM   #3
Re: Pxw-x70
I use a mono XLR microphone and record to both channels on the camera, manual on one, and auto on the other channel. I never experienced a problem.
Roland Achini is offline   Reply With Quote
Old February 1st, 2016, 12:38 AM   #4
Re: Pxw-x70
Switch both channels ( Channel 1 and 2 ) to Channel 1, switch off auto and manually set the audio level on a mono XLR mic plugged into Channel 1, no problems then I think.
Mike
Mike Griffiths is offline   Reply
