Sony AX100: 9,3 - 111,6 mm lens. Focal length (equivalent to 35 mm)? at DVinfo.net
Sony 4K Ultra HD Handhelds
Old February 2nd, 2018, 12:57 PM   #1
Hi, I'd like to know which the the focal length (equivalent to 35 mm) of Sony AX100. I mean optical zoom. It is 12x. Thanks for some info.
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos
Adriano Moroni is offline   Reply With Quote
Old February 2nd, 2018, 01:11 PM   #2
Re: Sony AX100: 9,3 - 111,6 mm lens. Focal length (equivalent to 35 mm)?
Full camera specs including this info is available online. Sometimes Google is your friend.
Ken
Ken Plotin is offline   Reply With Quote
Old February 2nd, 2018, 03:28 PM   #3
No, Google is not my friend and neither Sony. On Internet it is impossible to know it and on Sony site I read: 9,3 - 111,6 mm are equvalent to 29-348mm. I think it is impossible that 12x are 348mm. It is too much. Maybe they consider also the electronic zoom? For this reason I'm asking that question.
Old February 2nd, 2018, 03:36 PM   #4
You just need to know the crop factor for 1" sensor and multiply. Google that.
Mark Rosenzweig is offline   Reply With Quote
Old February 2nd, 2018, 03:47 PM   #5
Here there are the specs: https://www.sony.com/electronics/han...specifications
Old February 2nd, 2018, 04:39 PM   #6
Vortex Media
Here's a page from my upcoming Z90 training video. The AX100, NX80, AX700, and Z150 all use lenses with the same specifications.
http://www.dvinfo.net/forum/images/attach/png.gif
Sony AX100: 9,3 - 111,6 mm lens. Focal length (equivalent to 35 mm)?-z90-lens.png
Old February 2nd, 2018, 05:04 PM   #7
Thanks a lot
Old February 2nd, 2018, 05:08 PM   #8
If I"m guessing right you want to know how the ax100 focal length translates to the focal length of your gh5 lenses?
Like Doug has shown and what also is available on the spec list link you provided show that the ax100 has a f=29.0-348.0 mm (16:9) 35mm equivalent focal length.
If you want to know how that translates to your gh5 you need to divide those numbers by 2 so to cover the same focal length as the ax100 has on your gh5 you need a lens that can go from 14,5mm to 174mm. The only lens that I know of that comes close to this is the 14-140mm from panasonic, if you then would use the ETC mode from the GH5 you could about get the same reach, depending ofcourse if you shoot HD or 4K.
Old February 3rd, 2018, 01:57 AM   #9
Take a mm or two off when using Active SteadyShot.
Paul
Old February 3rd, 2018, 04:04 AM   #10
Does it matter to most people? I just zoom in or out to what I require on the screen. Total amateur.
A little knowledge goes a long way but not long enough.
Donald McPherson is offline   Reply With Quote
Old February 3rd, 2018, 07:01 AM   #11
Vortex Media
Yes, it matters a lot. Saying a lens has a "12x optical zoom" means absolutely nothing without knowing the numbers behind it.
Old February 3rd, 2018, 05:07 PM   #12
Back in the old days of video cameras, when all of them were roughly 40mm wide angle, the 12x or 14x was just basically a telephoto identifier.
Paul
Old February 3rd, 2018, 09:32 PM   #13
Vortex Media
What kind of video camera are you talking about? On a 2/3 Betacam the focal length had to be less than 8mm to even be considered close to wide angle. On consumer camera, even less than that. Even on on a modern full frame DSLR 40mm is not wide.
Old February 3rd, 2018, 09:52 PM   #14
I am talking about those old shoulder home video VHS camcorders, or similarly large 8mm "Handycams".
Paul
Old February 4th, 2018, 03:09 AM   #15
Vortex Media
And you're saying that 40mm was wide? I find that hard to believe with such small sensor/film sizes.
Doug Jensen is offline   Reply
