Sony a57 metadata help at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old July 13th, 2013, 05:00 AM   #1
Hi all,
I'm not sure exactly which category this fits into, so sorry if its in the wrong one - could be sony dslr, avchd or this one! confused!
Anyway...
I'm using Adobe Premiere CS6 evaluation as I want to upgrade soon. All my avchd clips start at 00:00:00:00 timecode. I know what I did wrong - apparantly you have to copy the whole card to the hdd and this transfers the metadata such as timecode into premiere. However, I've done this, and the clips all still start at zero.
My question then, is does the Sony a57 contain this metadata to carry over, or am I still doing something wrong?
Thanks for the help - pulling my hair out!
Russ
Sony Alpha a57 | RODE VideoMic | Adobe Premiere CS5
Manfrotto 785b | Manfrotto 718b
Russ Holland is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
