A7S S-Log footage at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old October 13th, 2014, 02:29 PM   #1
A7S S-Log footage
Does anyone have any footage from a A7S, just wanted to see how the footage holds up to grading, etc?
Because it seems the output through HDMI won't allow true S-Log by the comments I've seen, so wanted to see how the in camera holds up to colour grading and how much leeway you get with it.
Matt Thomas is offline   Reply With Quote
Old October 14th, 2014, 01:11 AM   #2
Re: A7S S-Log footage
There are a couple of links on dvinfo where you can download A7S footage, 24p and 50p but I can't currently locate them. Seeing you are in the UK I have re-uploaded the 50p footage from one of the Dutch posters who kindly posted a link to this footage originally. Included is an MP4 encoded at 5000 kbps where I had quick play at having a grade of the material. I found the footage quite solid to work with in spite of it being 8-bit.
www.sendspace.com/pro/dl/6lsxs9
Chris Young
CYV Productions
Sydney
Old October 14th, 2014, 03:10 PM   #3
Thanks, I'll take a look. I was just wondering if with it being only 8 bit, it would be that good at grading, as it seems may struggle to get 10bit out of it with the current issue of the HDMI not outputting the correct range of the S-log to the external recorders.
Old October 15th, 2014, 12:25 AM   #4
The A7s has no ten bit capability. It is HDMI 8-bit only although it is 4:2:2.
If you are interested in how to handle and get the best out of the footage from the A7s Alistair has done a pretty comprehensive job in covering these topics.
Exposing and Using S-Log2 on the Sony A7s. Part One: Gamma and Exposure. | XDCAM-USER.COM
Alister’s Blog | XDCAM-USER.COM
Chris Young
CYV Productions
Sydney
Old October 15th, 2014, 06:04 AM   #5
Oh right, I thought it outputted 10 bit from the HDMI, guess not.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
