A7s Auto override manual focus at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old July 30th, 2015, 04:22 AM   #1
My EA50 has a 'one-shot' push focus that allows me to engage auto focus while in manual mode. So what I'm wanting with my A7s is to have it in manual mode but press a button that does an auto focus while the button is down and then back to manual when released - surely I should be able to do this with the shutter release button? Can't see how.
Any ideas?
Old July 30th, 2015, 06:02 AM   #2
Sponsor: Westside AV
Re: A7s Auto override manual focus
Any ideas?
The AF/MF (Auto focus/manual focus) button can be used to do this. It can be used while shooting video.
This is from the help guide:
Help Guide | AF/MF control
AF/MF control
You can easily switch the focusing mode from auto to manual and vice versa while shooting without changing your holding position.
Switch the AF/MF/AEL switch lever to the AF/MF position, then press the AF/MF button.
During auto focus:
Temporarily switches the focusing mode to manual. Adjust the focus while the AF/MF button is being held down.
During manual focus:
Temporarily switches the focusing mode to auto while the AF/MF button is held down, and locks the focus.
Hint
If you select [AF/MF Ctrl Toggle] in [AF/MF Button] under [Custom Key Settings], the focusing mode remains switched even if you remove your finger from the button.
Old July 30th, 2015, 01:11 PM   #3
Thanks Olof - works a treat
Pete
Peter Rush is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
