Cleaning the Sensor at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old August 7th, 2015, 04:21 AM   #1
Cleaning the Sensor
I change lenses a lot during a wedding shoot and it's getting round to the fact that puffing away with my air blower only does a so-so job, I have a few spots that blowing cannot shift
I used Photographic Solutions Sensor Swabs with my EA50 but the A7s sensor is so much bigger for some reason I'm loathe to touch it but honestly cannot send it away to be cleaned every time - it would break the bank.
With such an exposed sensor I'm guessing you all have this problem so your safe solutions would be most welcome
I'm now thinking instead of swabs and fluid one of these
http://www.bhphotovideo.com/c/product/712189-REG/Visible_Dust_5964480_Arctic_Butterfly_724_Super.html
Pete
Old August 7th, 2015, 07:18 AM   #2
Re: Cleaning the Sensor
Hi Pete,
I have had some success with Kinetronics Speck Grabber.
Old August 7th, 2015, 10:15 AM   #3
Peca pad + Eclipse cleaning solution
Never had a problem. Cut and fold swab to whatever size you need. Use it to clean your lense too.
Amazon.com : Photographic Solutions Eclipse Cleaning System Solution : Camera & Photo
Pete Cofrancesco is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
