Avchd vs xavc at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old August 11th, 2015, 02:00 AM   #1
Avchd vs xavc
Has anyone any take on if XAVC is better than AVCHD? The files are way bigger and I've no time at the moment to do a comparison regarding quality/latitude/compression etc - anything out there to look at?
Pete
Old August 11th, 2015, 09:18 PM   #2
Re: Avchd vs xavc
I've used both extensively. For interviews with light grading expectations there is no real difference. If you shoot any fast action AVCHD will fall apart with muddy micro-blocking fairly easy. XAVC will hold up. In short, if I have the option I won't be using AVCHD anymore.
MediaSpigot LLC
http://www.mediaspigot.com
Ryan Douthit is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
