Battery status disappearing at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old August 27th, 2015, 04:43 PM   #1
Guys, I don't know what's going on but now the battery status on my A7S only shows up for a couple of seconds and then it goes away. I have to click the "display" options for it to show up again...but it only shows up for a couple of seconds and then it disappears again (along with the M symbol - as in manual). Did this ever happen to anyone??
The weird thing is, this only started happening after I've used a Neweer battery grip on the A7S. I was shooting an interview and I could see the battery status, but then the first battery ended and I couldn't see the status anymore. I've tested with single batteries and then with the grip again, but it remains the same.
If I select the display mode where ALL the info is displayed, then the battery status stays there...but there's WAY too much information along with it.
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old September 1st, 2015, 05:54 AM   #2
Re: Battery status disappearing
Apparently only the 'all info' display mode keeps the battery status visible (it's automatically hidden after a couple of seconds in the other display modes), i.e. it's a software thing not anything related to your grip.
Malcolm Debono is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
