Frame Rates at DVinfo.net
Old August 1st, 2007, 03:10 PM   #1
Frame Rates
Can any one share best practices when mixing frames rates in the edit suite, using FCP. IF a project was shot in 24P and there is existing footage in 60i, what have you found to be a best practice to mixing frames rates.
In FCP using a 24p time line and then inserting 60i material it is jerky, it discards frames.
Regards
Steve
Steve Cahill is offline   Reply With Quote
Old August 2nd, 2007, 01:51 AM   #2
FCP has never been very good at frame rate conversion, as you say it either dumps or adds frames with no form of smoothing or interpolation. Nattress has a very good FCP frame rate conversion plug-in that gives a much better result.
I wold work at the frame rate of the majority of your material, or your final output frame rate.
Old August 3rd, 2007, 10:30 AM   #3
Try the Nattress conversion filters ... www.Nattress.com.
-MW
Mike Watson is offline   Reply
