SD detail page in F3xx cameras at DVinfo.net
Old July 24th, 2008, 03:27 PM   #1
Taken away too young... rest in peace Eugene
Does the SD detail page specify settings for DVCAM mode recordings being made or for the downconverted firewire output of a HD recorded clip? Or both?
And depending on the above, are the detail settings in the regular detail menu page overridden by these when shooting in DVCAM mode or downconverting?
Thanks.
Scorpio Productions
PDW-F335, PDW-U1, Vegas Pro 9.0b
Eugene Kosarovich is offline   Reply With Quote
Old July 25th, 2008, 01:24 AM   #2
I've experimented with that some time ago.
I'm not 100% sure but this is what i concluded from testing:
SD detail works on the downconverted (capture with AVC mode) HD to SD image. The detail setting in the paint menu works at the recorded image in both SD and HD.
XDcamHD F330, 2" VF, Fujinon 13x3,3. 550D, MagicLantern, CS5.5
www.picturethis.tv
Eelco Romeijn is offline   Reply With Quote
Old July 26th, 2008, 02:12 AM   #3
#1 : yes. You can see the result directly when watching a SD pic hooked up thru FBAS/component, too. The "low" "mid" "high" setting directly changes the crispness of the SD converted picture.
ULI
Uli Mors is offline   Reply
