F330 - from Factory settings to real world shooting? at DVinfo.net
Old January 27th, 2010, 08:12 AM   #1
Finally I have the camera quite ready to start shooting with it. The batteries arrived and is working, I have updated all the firmware...
During the update I was instructed to reset all settings to Factory Settings.
I'm not sure exactly how much "trouble" this gives me... But I'm quite sure that some new setting has to be made.
Yes - I know that there are no general settings and that a lot depends on the users preferences. But I'd like to have some help here...
This is also my first ENG camera since I've only been using HDV cameras before (Canon XHA1). So there sure are some differences in camera use.
QUESTIONS:
1. Your prefered settings (in general)
2. Should I use auto iris or not
3. My Gain settings are 0db, 9db, 18db.
18db seem to be really unusable. Even 0db gives some grain (test shots inside, natural indoor lighting).
4. How the hell can I see if the exposure is right in the viewfinder? :) - Basically with Zebra?
(Used only the LCD on my Canon XHA1).
5. Any preferred PAINT settings that I should be aware of? (I think that my test shots are a bit to washed out in the blacks and quite noisy).
6. I have no Scene files at the moment... Which ones are good compared to "factory style"?
7. Do you guys turn on and of the Skin Detail from time to time?
Other things that might be good to know?
Are there any "First time shooting with ENG camera guide"? :)
Joachim Ljungquist is offline   Reply With Quote
Old January 27th, 2010, 08:27 AM   #2
Images: 1
Yes, I sent you a private message regarding my training DVD. It explains in detail for first time users of full ENG style cameras.
-gb-
Old January 27th, 2010, 11:53 AM   #3
Vortex Media
I would recommend these two videos:
F-350/355 training
Vortex Media: VIDEO & PHOTO Tools and Training
Lighting and Exposure
Old January 27th, 2010, 12:09 PM   #4
Vortex Media
These are the only paint settings you need: I've been using them for over four years.
MATRIX = ON / HiSat
GAMMA = CINE4
MASTER BLACK = -3
BLACK GAMMA = -2
That's really all you need to change. In fact, based on your level of experience, I would stongly suggest that you NOT change any other paint settings until you can answer some of your other questions yourself - particulary #4.
Old January 27th, 2010, 12:38 PM   #5
Thanks Greg - and yes, I know the answer is (partly) Zebra...
I'd say that I'm quite experienced in video production - but the way to work with this kind of camera is a bit different from many semi-pro HDV cameras, as my XHA1 for example.
Old September 7th, 2010, 10:14 PM   #6
MATRIX = ON / HiSat
GAMMA = CINE4
MASTER BLACK = -3
BLACK GAMMA = -2
With these settings, is everything else "zeroed" out? Or do you use these in addition to the scene files? I primarily do news and most of the majority of the time the video will come out of the camera, into the editor with no color grading.
www.marshallstaton.com
Marshall Staton is offline   Reply With Quote
Old September 8th, 2010, 04:46 AM   #7
Vortex Media
No, everthing else is NOT zeroed out.
The settings I listed previoulsy are the only ones that are different than the "Standard" values. -- and many of those are not zeroed out.
Copy the "standard" paint file settings to one of the blank memories so you start fresh, and then make the changes recommended above to fine-tune the camera.
I guarantee your camera will look great and require no grading.
Old September 23rd, 2010, 07:45 PM   #8
MATRIX = ON / HiSat
GAMMA = CINE4
MASTER BLACK = -3
BLACK GAMMA = -2
Doug, I've got your dvd but curious to why i can't adjust my master black and the black gamma will only go to 0 and -3 and so on. It won't let me do -2. This is also a pdw-f350 if it matters. Thanks!
Old September 23rd, 2010, 08:04 PM   #9
My mistake the master black i just had to spin the wheel more than one click, sorry rookie mistake.
Old September 24th, 2010, 07:20 AM   #10
I would not call that a rookie mistake, I would call it a bug with the camera
I have the same problem and often have to turn the knob like a madman to get any action on these settings
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply
