HELP! Quick 24 questions at DVinfo.net
Old October 27th, 2006, 11:22 PM   #1
Can somebody give me a fast answer to this?
I've noticed a blurring of video when moving even at slow speeds in 24p. Does using a 48 shutter speed help counteract this movement blur? I will be panning across a lot of detail on paintings, and it needs to be relatively readable.
If it doesn't then I may be faced with switching to 1080i to shoot the bulk of the remainder of a shoot.....
If so, are there effective, non-jerky ways to translate 24p footage back to 1080i?
BW
Bill Weaver
Across Borders Media / Media that Matters
Bill Weaver is offline   Reply With Quote
Old October 28th, 2006, 04:00 AM   #2
You need 1/48th shutter, and then a slower pan. If you pan at medium speed you will get judder.
Simon Wyndham is offline   Reply With Quote
Old October 28th, 2006, 08:51 AM   #3
24 is 24. You can only do things so fast. If it seems wrong or weird, just remember documentary filmmakers have been working with those limitations for decades...it won't degrade your work.
My Work: nateweaver.net
Old October 28th, 2006, 03:03 PM   #4
24 and 25 P creates some interesting effects. Very slow pans and moves work, medium don't, but then fast moves and pans work again. On a really quick pan or move you don't "see" the judder that really stands out in medium speed moves. 1/48th shutter gives less blur, but depending on the move speed can increase stutter. I have also found that the judder seems to look worse in the viewfinder than on a large monitor, don't know why!
Old October 28th, 2006, 03:14 PM   #5
If you are shooting with your none viewfinder eye open, with your other eye looking at the viewfinder, then the judder will be more noticeable.
A lot of people I speak to are worried about progressive scan, and seem to look upon it as a dark art that you need to be really careful with.
Fact is, when everything is edited together and you are watching things normally on a TV, you won't notice it anywhere near as much.
For example, when you watch 24 do you notice the judder? Its frantic handheld camerawork should make it stand out like a sore thumb. Yet it doesn't.
My advice to anyone shooting progressive scan is not to worry so much, and don't over analyze the footage.
Old October 28th, 2006, 05:50 PM   #6
Good points Simon.
I was asking my girlfriend the other day to tell me which footage she preferred the look of between some interlaced and some progressive. She said she preferred the progressive as it looked smoother and more film like. Then I asked here if the judder bothered her. She said she had not noticed it until I pointed it out and she then looked for it.
Nigel Cooper is offline   Reply With Quote
Old October 29th, 2006, 01:49 PM   #7
Telecam Films
I've noticed a blurring of video when moving even at slow speeds in 24p. Does using a 48 shutter speed help counteract this movement blur? I will be panning across a lot of detail on paintings, and it needs to be relatively readable....BW
Bill,
In my experienced, using a 48th/sec. shutter speed does not help at all. You just have to pan either really slow or at a fairly good speed. For the type of art shots you described, I would strongly advise you to shoot in 30p or even 60i. I recently shot a program on Rembrandt for NHK, doing a lot of camera moves accross painting at different speeds and different angles and I am glad we were working at 60i.
If you have an edit system that can ingest video via HD-SDI, you may want, depending on contents, to consider shooting at different frame rates. I am working on a doc now that involves quite a few table shots of different artifacts (shot at 30p or 60i) mixed with stock footage (SD at 30i) and interviews / GVs (shot at 24p). I am editing in an AVID 1080 60i project and use the XDCAM HD deck built-in frame rate conversion feature to ingest everything as 1080 60i HD video. Works great! Unfortunetly, if you want to edit in FAM mode (MXF file transfer), you do not have this flexibility. As of now, it is not possible to change frame rates or to add pulldown when importing XDCAM clips via FAM.
Thierry.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old October 29th, 2006, 02:15 PM   #8
Indeed some projects are better in interlaced. High def for me doesn't have the same cheap video look when interlaced that SD does.
But if the director wants 24p, then that must be worked around.
For example, is it absolutely unnecessary to pan across the paintings, or is there another better creative way to do things?
Old October 29th, 2006, 04:14 PM   #9
Here are my discoveries after my initial shoot yesterday with Canadian painter Robert Batemsn:
I'm glad I'm working in 24p, as it gives the piece a more classic look, which is what I am looking for.
I shot using very little detail (20 out of 150)
I found 48 shutter to be mainly a limitation, as it seemed to cause filckering and stobing with backround vegetation and with blades of grass. Most of these shots are too distracting to be used. I'll try to slightly soften ones that are must-have.
I shot rest of day in 24p, no shutter, and everything worked well. It still feels film-like.
I did some test shots with very slow paning across canvases, and all seemed AOK.
BUT -- here's something I can't figure out. In some cases, bright sky shots and other overexposed spots seem to pulse and/or clamp. Any ideas on what might be causing this?
Bill Weaver
Old October 29th, 2006, 04:45 PM   #10
I've had serious iris hunting for the first time with the new firmware, where I'd never had it before. I believe there's an iris response setting in the maintenance menu, I might have a look at that.
Old October 29th, 2006, 04:48 PM   #11
Detail is important with filmlook. Turning it down is good. Usually I'd turn it off completely with progressive scan.
Did you have the DCC on? The DCC on the XDCAM HD I have found seems to have some pretty bad 'hunting' issues. I had hoped that it would be fixed in the latest firmware.
Old October 29th, 2006, 05:00 PM   #12
Wasn't using auto iris. It was like the sky started flashing. Never seen this before. Any other ideas?
I'll check on that. Unfortunately, I do not yet have latest firmware.
Bill Weaver
Old October 29th, 2006, 05:17 PM   #13
Definitely sounds like the DCC. Can you check whether it was on?
Old October 30th, 2006, 02:41 PM   #14
Did you have zebra on that was just starting to show?
Old October 30th, 2006, 03:28 PM   #15
Images: 1
1/48 shutter equates to the 180 degree shutter angle that is standard on motion film cameras. The flickering and strobing of background vegetation and blades of grass during pans are part of the reason shallow DOF is used because it hides that ugly side-effect as you follow the main subject.
You may see 1/48 as a limitation, but it's been standard practice for many years.
Shooting 24p means you have to adapt your technique to that of the way standard motion pictures have been done for years.
-gb-
Greg Boston is offline   Reply
