premiere pro and xdcam HD at DVinfo.net
Old February 11th, 2007, 04:43 PM   #1
Any news on editing native Xdcam HD in premiere 2.0?
I've seen the workflow on FCP on a Mac and i love the files import
so what's about the Mainconcept plugin, i heard it has problems and hangs from time to time...
Any info would help.
Tony Partamian is offline   Reply With Quote
Old February 11th, 2007, 05:23 PM   #2
MainConcept plug-in
The MainConcept plug-in is not the greatest, but the 2.0.1 version at least works. 2.0.0 was really horrendous. Probably one more update and it will be tolerable. It also promises things it doesn't yet deliver, like presets for Bu-ray and HD DVD output.
There's a great manual you can download, don't have time to pull the link right now but it can be scared up on the MainConcept site. It not only tells much about the program but is practically a post-graduate course in MPEG and related codecs and all their variables and permutations. Worth a look whether you buy the plug-in or not.
And for not much more than this plug-in costs you can buy Vegas, which seems to handle 35 Mb/s ingest from XDCAM HD better than Premiere with MainConcept does. The Vegas MPEG codec is created by guess who, of course MainConcept. But anyway, buying Vegas would be an alternative to consider.
Tip
Tip McPartland is offline   Reply With Quote
Old February 18th, 2007, 03:08 PM   #3
Problem is i use Blackmagic Decklink board and like to use the output for monitoring.
I will give MainConcept a try and see if i can import XDCAM HD file in a BM project.
Old February 21st, 2007, 06:13 AM   #4
Hi Toni,
I have the same setup (PP 2.0 and Decklink), and tried Main Concept. Doesn't work.
Look at they answer:
Dear Mr Becker,
we know about the memory issues and we are working on a solution.
The problem is that we don´t know what cause this memory issues and we are not sure if our plugin or if Premiere will have this problem.
We will still investigate this problem and we try to solve it as soon as
possible.
Best regards,
Marc Hartmann
Gérson Becker - Lumiere <gerson@lumiere.com.br> schrieb:
> Hi Marc,
> I was waiting for a brand new computer to try the plugin again.
> The config: Motherboard Intel D975XBX2KR, processor Duo Core2 6600 2.4GHz, 2
> GB Ram, XP Professional service pack 2 up to date.
> Premiere 2.0 and MPEG Pro 2.0.1
> I tried XDCam HD in all formats: 24p, 30p, 60i, 25 and 35Mbits.
> After import 8 to 10 files, Premiere shows this message: Adobe Premiere Pro
> is running very low on system memory. Please save your project and proceed with caution.
> After this computer stops. I try the timeline and nothing happens.
> Gérson Becker
Vegas works fine with Decklink, but I can't get 30fps at 1080i. Only at 720p.
Maybe after NAB we gona see a solution for Premiere and XDCam.
Gerson Becker is offline   Reply With Quote
Old March 28th, 2007, 11:47 AM   #5
Finally released some info on Premiere Pro CS3. Still no indication of .MXF support...:(
http://www.adobe.com/products/premiere/
Bob Armstrong is offline   Reply
