-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   DV OUT workflow (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/89670-dv-out-workflow.html)
Uli Mors March 23rd, 2007 02:27 AM
DV OUT workflow
If working SD and NOT wanting to convert HD into SD in my NLE, does the DV Out behave like a tape based system?
Exactly: Can I use batch cap tools like scenalyzer with it?
I know about the advantages of the disc + FAM and love it, but IŽll have certain projects where I am will probably do (shoot) HD but capture DV.
(Explanation: I am working with Vegas. Regarding big projects Vegas has not to render cut projects (DV AVI) as long as no effects / scaling is done. Therefore EXPORT is very fast).
Contrary to this, any MXF (MPG) has to be rendered first. For "fast" projects in SD (filmed in HD) it looks faster FOR ME & my workflow) to capture DV from the Fiwi-out)
I was wondering if batch capturing etc. works the same way I am used to with my Panasonic DVC200.
ULi
Vincent Rozenberg March 23rd, 2007 03:27 AM
Yes, it does work the same as good ol' DV tape.
Greg Boston March 23rd, 2007 08:22 AM
With the added benefit that using the transport controls in the NLE to scrub back and forth is a very quiet operation, unlike tape based units. Plus, it doesn't induce as much wear and tear!
You probably already know this, but if you are using AV/C mode for firewire, you can have the camera crop the 16:9 to 4:3 during playback so that it doesn't have to be done in the NLE.
-gb-
Uli Mors March 24th, 2007 09:12 PM
just to be sure:
The F330 cant be switched to output HD (18/25/35) via firewire in realtime, correct? Transfering HD means go FAM always?
ULI
Greg Boston March 25th, 2007 01:28 PM
Originally Posted by Uli Mors (Post 647728)
just to be sure:
ULI
That's correct and true for both cameras. There is no HD stream from firewire, only file transfer in FAM mode.
FAM mode- device looks like an attached drive to Windows/Mac
AV/C mode- device looks like a deck to Windows/Mac
-gb-
