Hdr-hc9?? at DVinfo.net
Old March 1st, 2008, 07:28 PM   #1
Hdr-hc9??
Next week I am planning to buy the HDR-HC9. I have thought about the hv30 but I still like the HC9. I also plan to buy the NP-FH100 Info-Lithium how long can I expect this battery to last per charge? Also how long does the battery that comes with the battery also last? Thank you all!!! Looking forwad to it.
Walter Scriptunas is offline   Reply With Quote
Old March 2nd, 2008, 02:51 AM   #2
from the manual - for the fh60 stock battery, 50-55 minutes in "typical usage" - i.e. on/off, zoom, etc continuous record 90-100 min.
The FH100 is a big beast and sticks out the back quite a lot, but is rated 185-205 typ, 345-375 continuous
Personally I prefer the FH70 at 80-85 typ, 150-160 continuous... and the same physical size as the FH60.
Don't know if they stiffened up the HV30 any, but I would guess that the same comparisons between the HC7 and HV20 apply build quality wise. The HC9 is still the same "built like a tank" feel - solid, and sexy in black...
Old March 2nd, 2008, 10:35 PM   #3
Thanks. I may just get two FH70's. The FH100 just seems to big.
Old March 3rd, 2008, 11:53 AM   #4
the stock batt, last about an hour. have the 70, is good for about 140 min
Karl Heiner is offline   Reply
