A1 shoe on HC1
Is there any way to convert the flash on the HC1 to the A1 shoe? I'm willing to sacrifice the flash since I never use it anyway. Can any A1 users shed some lights on how that shoe is mounted on there and how difficult it'd be to convert it?
Btw, I've tried making an adapter for the AIS shoe but it's still not very stable. Also tried an extended shoe connects via tripod mount and didn't like that very much either. |
No.. other than trying something home-made like you have done.
Mark |
Everyone has the same issue with the HC1.
People either have to buy AIS-fit accessories (v annoying) OR build your own adaptor to fit into AIS to convert to normal cold-shoe (several people have done this) OR buy an A1 and then you have a cold-shoe to bolt on almost anything you want. I'm very surprised no 3rd-party company hasn't yet manufactured a little plastic/metal converter to change AIS to cold-shoe. Maybe they have and we just don't know about it.. |
I dunno if it is even possible to make a stable adapter to fit the AIS shoe (for big accessories anyway). I took apart the sony 3 watt light to create a shoe but that turned out less stable than the piece of metal I filed down to fit the shoe. That's the reason why I wanted to convert the flash to the A1 shoe. I asked because I was hoping I can order the A1 parts from sony and maybe unscrew the flash and put the new shoe on.
EASY & Cheap Sony AIS Shoe Adapter
I'm not advertising anything here, but on my website, I have a page with pictures and instructions on how to do this. Visit: www.jcdv.com/shoeadapter.htm Very simple and sturdy. It held a Bescor light with the 6 volt battery very well. Good luck! |
He used a piviting (front-to-back) German-made cold shoe adapter, in which the bottom shoe (which is plastic, thus no fear of shorting out the AIS socket) is cut to an "I" shape and part of the base is relieved so that you can insert it into the AIS socket, press down and slide forward. It's very nice without any play in the socket. |
I appreciate all the different adapters that people are coming up with and I'm very glad that you're satisfied with the results. However, I think I've given up on the AIS shoe. I still use the adapter I've made even though I'm not totally satisfied with it.
I think at some point I might use JB weld to attach a coldshoe to the flash. I'm considering buying the A1 XLR block also so it'd be good to keep the AIS free. Of course I'd have to confirm that all the HC1 firmware works with that first but that's another story. Thanks for all the effort. |
If I do want to use an AIS product, then I can off-load the non-AIS mic or light to a BESCOR cold shoe adapter/handle. |
Thanks Jerome.
Nice job showing and explaining. I've been considering a Rode Videomic, but didn't want to sacrifice my tripod mounting ability to use one. Have you tried one on it? Looks like a good workaround. Jamie |
| All times are GMT -6. The time now is 03:53 PM. |
