Where should I set my manual audio setting? at DVinfo.net
Old June 20th, 2006, 10:48 AM   #1
I have the HC1 and have some audio questions.
I am using a Beachtek DXA-2s connected to the camera via the minijack and a Rode VideoMic (minijack) and wired lavalier (XLR) connected to it.
My questions are:
*Where should I set the Manual Audio setting on the camera?
*Do I set it all the way up and use the gain control on the Beachtek to adjust the audio levels?
Thanks in advance!
Charlie Vankirk is offline   Reply With Quote
Old June 20th, 2006, 11:55 AM   #2
I have the DXA-6 on a FX1.
I found that if one push the Manual setting all the way up there is a lot of hissing noise.
I keep the manual setting on about 5 (middle) and make any adjustments on the Beachtek.
Worked good thus far.
Pieter Saayman is offline   Reply
