A1U/line in VF at DVinfo.net
Old August 18th, 2006, 12:07 PM   #1
A1U/line in VF
Recently noticed a thin white verical line in viewfinder close to right side. It's not on lcd or on tape. Not a dealbreaker, but has anyone else noticed this? Camera is less than a month old and I don't think it was there.
thanks,
chris
Chris Li is offline   Reply With Quote
Old August 20th, 2006, 07:37 AM   #2
I just checked and I don't seem to have it.
Is it on the border or a little more inward?
Tommy Haupfear is offline   Reply With Quote
Old August 22nd, 2006, 04:33 AM   #3
thin line
Don't have one on mine. If new, I'd return it. Too much money for even minor defect IMO. Is on LCD panel AND the eyepiece finder? If in only one place, likely that component is defective.
James Harring is offline   Reply With Quote
Old August 23rd, 2006, 12:11 PM   #4
VF line is still there
As stated before, the line is faint and only noticable in lower light situations. Outdoors I can't find it. Indoors against a plain wall I can maybe see it.
the line runs verically from about the colon btw. the seconds and the frame numbers of TC in upper right of frame to about the "E" in "P-MENU" in lower right of frame.
I've seen these kinds of white lines on other camera vf's before, some worse than others, but I would only be concerned if line got worse than it is now.
chris
