HD1000 Digital telephoto at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
Sony HVR-HD1000
Sony's single-CMOS shoulder mount HDV camcorder.
Old April 4th, 2009, 03:55 AM   #1
I've this cam just from a few days, wat's is your opinion about the use of digital duplicator 20X, it's seem to be surprisingly usable for the short test i've recorded.
videoaviation.com
italy
Maurizio Amelotti is offline   Reply With Quote
Old April 4th, 2009, 10:30 PM   #2
It works remarkably well, probably because the chips have more pixels than needed for HD. From my quick tests though there is a slight jump as the camera switches from optical to digital zoom.
Old April 5th, 2009, 06:28 AM   #3
Thx for the reply, maybe it's not my impression about the good quality of dig-telephoto, i remember in the past camcorder with orrible resolution......
videoaviation.com
italy
Old April 5th, 2009, 10:42 AM   #4
I've not had to use it (I think I have it turned off which has always been my policy). I do have a Letus though and I have a telephoto fixed 35mm lens that I've used with good results. But mostly I use that on my HC9 because of the form factor (the HD1000U isn't set up for a Letus).
One thing I like about HD is that you can crop and zoom in post to fix bad framing. The result is good and except to the trained pro, not that noticeable.
Jonathan W. Hickman is offline   Reply With Quote
Old April 10th, 2009, 02:50 PM   #5
Just a little test, nothing to scientific, filmed on HDV, downcvrt on PAL SD:
RapidShare: Easy Filehosting
videoaviation.com
italy
Old April 19th, 2009, 10:17 AM   #6
Archivist for SMECC
by default is it turned off?
I have had some nasty footage eih it zoomed all the way in. is this digital tele on by default?
http://smecc.org/video/KKAT-TV_ED_SHARPE.gif
See The Communications and Computation Museum at:
Museum Website
See The Glendale Arizona Videosphere - KKAT-TV At:
Glendale Daily Planet KKAT-TV CouryGraph Productions
Click For Red Camera In Action
Ed Sharpe is offline   Reply With Quote
Old April 21st, 2009, 11:48 AM   #7
The digital tele is off by default, or at least so says my manual :)
James McBoyle is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony HVR-HD1000
