Backfocus service @ Sony at DVinfo.net
Sony HVR-V1 / HDR-FX7
Old September 3rd, 2008, 03:02 PM   #1
Has anyone on here had Sony Service fix a backfocus issue on a V1U or any similar camcorder that was out of warranty? I would like to have an idea what I am getting into before I send it in. I talked to the Sony service center in LA and they said they have done this service numerous times but wouldn't give me an estimate over the phone. Their estimate charge is $135.00, but they only charge that if you don't repair the unit. Which is understandable I suppose. But I would like to have some idea if I might be looking at $500, $1000 or $3000. Personally, I think this should be a factory recall situation. But that doesn't seem to be likely.
Greg Laves is offline   Reply With Quote
Old September 4th, 2008, 12:20 AM   #2
you didn't get an extended warranty when you purchased?
Hugh Mobley is offline   Reply With Quote
Old September 4th, 2008, 07:31 AM   #3
No sir. I was not the original owner.
Old September 10th, 2008, 11:30 PM   #4
Mine started to lose back focus after about 10 months of use since I bought it new. It was fixed by Sony under warranty.
David Issko
David Issko
Edit 1 Video Productions
David Issko is offline   Reply With Quote
Old September 11th, 2008, 05:18 PM   #5
Greg it was Two hundred and change under parts warranty. I paid for the labor. Your looking at about five hundred. Good luck
Monday Isa is offline   Reply With Quote
Old September 11th, 2008, 06:57 PM   #6
Ouch. It has to be done. Unless I want to shoot everything in autofocus which doesn't appeal to me at all. Thanks for the info, Monday. One attaboy for you.
Old September 11th, 2008, 07:11 PM   #7
Or you can shoot at 3.2 -9 iris to get around the backfocus problem till you get enough to fix it.
Old September 12th, 2008, 09:40 AM   #8
You could use auto focus to get the initial focus and then toggle to manual to lock it in. By the way I had this back focus problem twice under warranty. The last time seemed to do the trick, but I connect the camera to my edit bay monitor and double check before each shoot.
www.leebergermedia.com
Lee Berger is offline   Reply With Quote
Old September 12th, 2008, 09:48 AM   #9
Interesting that worked for you Lee. For me nothing worked but stopping down on the f stop. I wish I had learned about it earlier as it messed up 3 jobs last year. To my benefit it was not the main camera though.
Old September 15th, 2008, 12:50 PM   #10
In your experience what has been the door to door turn around time on having this service done? Thanks in advance.
Old September 15th, 2008, 12:52 PM   #11
It took 1 week
