-   Sony HVR-V1 / HDR-FX7 (https://www.dvinfo.net/forum/sony-hvr-v1-hdr-fx7/)
-   -   sky overexposing: will French flag help? (https://www.dvinfo.net/forum/sony-hvr-v1-hdr-fx7/94409-sky-overexposing-will-french-flag-help.html)
Simon Hunt May 28th, 2007 02:44 PM
Originally Posted by Piotr Wozniacki (Post 687705)
OK - so by "Knee Level" you mean the degree of flattening the curve, and not where the switching point is located on it. You are right - BTW, the "level" as you understand it is not enough on the V1, IMHO - even with its strongest settings, which is "Knee Low"...
Thanks for the clarification. BTW, how does the "auto" setting for Knee work in your opinion? This often helps (on the F-900) if you are panning back and forth from, say, a wall to a bright window. Anyone tried the "auto" setting?
