Skateboarding shot with FX1 at DVinfo.net
Old August 7th, 2007, 11:51 AM   #1
http://www.bansheeproductions.ca/Den...arkAugust4.mov
likes or dislikes welcome.
- Pat
Pat King is offline   Reply With Quote
Old August 7th, 2007, 09:10 PM   #2
Little bit too much light Filter would help otherwise good looking video.
SONY HDR FX1E
Roman Oulko is offline   Reply With Quote
Old August 8th, 2007, 12:39 AM   #3
Images: 3
Some whites look clipped. You could check levels. Not easy to keep bright whites and clouds within camera range without under-exposing excessively. If clipping didn't occur on the tapes you can still make corrections before rendering out. Nicely shot and produced, I think.
Old August 9th, 2007, 02:42 AM   #4
Most of the times I use a graduated ND filter on my Z1, as I did on my PDX10. Even indoors it can be a great help.
In my case I have a matte-box, so it's easy to pull it out if not needed.
For me, a graduated ND is essential for ANY video work, to tame the highlights and stay within range. Unfortunately that is something that film is much better at.
Carlos E. Martinez is offline   Reply With Quote
Old August 11th, 2007, 09:17 PM   #5
Images: 3
In this case the grad wouldn't help. There is a lot of bright white in the action as well as in the sky. In general the concrete has been kept within range but the T-shirt is often blown out. A darker T-shirt would have been a good idea.
Old August 12th, 2007, 03:42 AM   #6
Overall Nice work mate,
I'm no professional or anything, but below is a few things i noticed just from a layman's view :) so no offense intended.
One thing i noticed was at the steps (00:00:12) - the camera dips for a slight moment before rising - did you mean to do this, or was it a lapse in concentration.
Around 00:00:45 there are a couple of frames that maybe shouldnt be there?
Same for 00:01:13 afterwhich we are sitting behind the guy, hand held - just before it there is an abrupt cut for like a split second (looks like it was left behind in editing), and the few seconds of the dude just sitting there watching the skate park, not sure what i was supposed to be looking at / for in that shot?
Like the follow sequence on the board - gets me right in there almost feeling what he's doing.
The slow motion is quite cool also, can you say a few words on your technique for that?
Did you use a crane of some sort at all (it looks like it - but ive never used one so not 100% sure)
Khaled Chatila is offline   Reply With Quote
Old August 14th, 2007, 12:03 AM   #7
Thought it looked great.
Can you tell us:
1. What kind of crane you used?
2. What kind of steadycam you used for the tracking shots?
-- John.
John Hewat
Mammoth Media Productions
John Hewat is offline   Reply With Quote
Old August 14th, 2007, 12:02 PM   #8
I was looking around and found the same post with your answer.
http://www.dvinfo.net/conf/showthread.php?t=100645
Joseph
Joseph Hutson is offline   Reply
