HVR-Z1U (PAL 50i)LCD at DVinfo.net
Old August 18th, 2007, 10:58 AM   #1
The camera in Pal lost quality on LCD panel and viewfinder is much worsa than in NTSC .I buy the camara for using it in Pal and I am safer now.In Pal ,if I do movement ,picture in LCD and viewfindes is micro flicker(someting like this?
Is enyone here who can tell someting about this?
Martin Gruber is offline   Reply With Quote
Old August 18th, 2007, 01:23 PM   #2
PAL has more lines and the lines are being squeezed onto the same screen being used for NTSC so detail is lost.
Old August 21st, 2007, 01:46 AM   #3
Are you sure you have the same settings in the menu for PAL and NTSC? You might have a PS mode that's different or maybe one is in cine-frame mode? That's much more likely than the lines difference, as in HDV mode PAL and NTSC are the same.
tom.
Old August 21st, 2007, 02:08 PM   #4
I thing is the happen because,Sony meke the LCD and viewfindes system for NTSC and Pal have more lines this make the efekt.
