Shutter Speed, Frame Rate, Smooth Slow Motion
Whats the optimal settings for slow motion? I'm thinking of is doing an action scene. Someone throws a punch and I slow it down in post then speed it back up. Am I right in thinking that the camera is only capable of capturing 60 frames a second and increasing the shutter speed won't add any more frames? I plan to use use a plugin in FCP to create smoother slow motion but wanted to know if there is anything I should be doing while shooting. How do the pros do it besides using a special slow motion film camera? There is an example on Twixtor site that shows what I'd like to achieve.
http://www.revisionfx.com/products/twixtor/ Last edited by Pete Cofrancesco; June 23rd, 2008 at 01:12 PM. |
Regardless of the shutter speed, the camera always captures 30 frames each second (or 25 if you set the Z1 for 50i), but the frames are divided into two fields that consist of the odd and even scan lines. Personally I would leave the shutter set to the default, which is 1/60 sec. But I would read all the documentation for whatever software plug-in you're planning to use. I suspect you will find some advice there about how to get the best results.
#3 | |
If you have after effects there is a time warp effect that looks like that twixtor video. I don't know the best shutter speed to shoot with, it would be interesting to know if a higher speed actually makes a difference, as opposed to 60. |
There are tools that can slow down footage reasonably well, such as Apple's Shake. Granted, it is no replacement for a camera that can be overcranked, but if you can't get one of those, then these software tools offer better results than simply duplicating or blending frames.
My rule of thumb is that I use a faster shutter when I shoot a scene that will be slowed down. For example, assuming I use 1/60sec for normal speed and I plan to slow it down to 50% of the speed, I'd set the shutter to 1/120sec for the shoot - same speed you'd use if you actually were overcranking the camera. That seems to produce usable results. - Martin
Martin Pauly |
#5 |
If you have FCP studio2 choose the speed you want the clip to run at and then render it. Now send it to motion. You need to pull up the inspector window.
Going by memory here because Im no where near the computer but I think it the "timing" setting. Change it to "optical flow" . This will take FOREVER even with a fast machine so do it at the end of the day and come back tomorrow. It wont replace overcrank or undercrank but it will smooth it out a bit. Warning though, if the clip you want to slow down is long then you need to cut out what you want to slow down and copy it and then apply optical flow . Otherwise it will apply it to the whole clip and that can take a couple of days |
#6 |
If I was interested in slowing down footage, I'd be very careful about selecting the shutter. For cinematic effect, a "180 degree" shutter is typical, which is 1/2 the frame duration.
The best slow motion is achieved by converting fields to frames. This means shooting 1080i60 will allow you to achieve 2x slow motion in a 29.97p video, and 2.5x slow motion in 23.976p video. In the fields->frames approach, the "180 degree" shutter is 1/120. If however, you choose a different slo-mo factor (4x for example), you will want to decrease the shutter to 1/240. In order to get smooth slow motion though, you will need some kind of motion estimation. You can use frame blending as well, but it won't be as smooth. Do NOT shoot with a 1/60 shutter. When you slow your footage down, everything will look like it has motion blur, but nothing will be moving. Using a high shutter speed is far more desirable. -Steve |
#7 | |
Interlace television was designed as a system exploiting the phosphor characteristics of a CRT display that to the viewer would perceive a full 60 frames per second image. The deinterlacing required by "modern" flat panel displays can make a complete mess of this conversion. To get to the question. Yes pros use a special camera that can record at higher frames rates. IF you have a consumer cam leave at 60i and shutter at 1/60 and let the software sort it out!!! Ron Evans |
#8 | |
That doesn't match my experience. Leaving the shutter at 1/60 results in motion blur being recorded that, to my knowledge, software is not capable of removing or reducing later. Not sure if the analogy is correct, but to me that would be similar to relying on software to remove reverb from an audio recording, which the experts agree is also not possible. Once it's blurry, the original crisp information is lost and cannot be recomputed. That doesn't mean that blur (or reverb) is a bad thing; it's just that the amount has to be just right to make it look/sound right. And with blur and reverb alike, it's easy to add more later, so if in doubt, I always err on the side of recording less rather than too much. The best slomo results that I've achieved (using the Z1 and Apple Shake) have been when the shutter speed was adjusted for the intended playback speed of the video. In other words, the actual shutter speed at the time of recording divided by the speed factor (e.g., 0.5 for half the speed) should be 1/60, such that the amount of motion blur visible at playback time is the same as what an appropriately overcranked camera would have recorded. Then the amount of blur looks right for the playback speed. - Martin
Martin Pauly |
#9 |
Martin, you are exactly right, and your reverb analysis holds. I can confirm this both as a visual effects hobbyist and as someone with significant scientific experience in image processing.
#10 | |
Ron Evans |
#11 |
Slow Mo for Canon XH A1
Hello,
Would people please shed a little light on the benefits shooting footage for slow mo in progressive (frame mode) as opposed to interlaced mode? In this query I would like to leave out the shutter speed... suppose you know what is your subject, what shutter speed you'll need and how many times you'd need to slow down (re-time) the footage. Many thanks. Regards, Pavel
The fish is the last to know the water. |
#12 | |
#13 | |
Btw the article you are referring is very informative, I wonder whether the has been something similar done for the 24/25f mode on the Canon XH A1. Thanks again. Pavel
The fish is the last to know the water. Last edited by Pavel Tomanec; August 25th, 2008 at 11:04 AM. |
#14 | |
#15 | |
If you're talking about the Canon XH A1, then shoot interlace at 50i and slow down using something like the Jes Deinterlacer (if you have a Mac). There's a good demo movie on the site that clearly shows the difference, the iMovie slow mo example is what you'd get if you slowed down progressive footage. You can slow it down exactly 50% of the original speed. Any faster and the slow mow might look a bit uneven, any slower and you'll start to see the stutter. |
