New article: Z1U Free Run TC as Ext. Sync. - Page 2 at DVinfo.net
Old October 16th, 2010, 08:03 PM   #16
Please update the link at the top of the page
Chris, I spent an hour searching for the article you wrote back in 2004 - I knew it's here some place, and I also knew you did some reorganizing, so I suspected it got moved.
The correct link is Using Free Run Time Code as an External Sync Substitute for HVR-Z1U Multi-Camera Shoots at DVInfo.net
Thank you,
Ervin Farkas
www.AtlantaLegalVideo.com
Ervin Farkas is offline   Reply
