CF25 HDV>DV possible? at DVinfo.net
Old December 4th, 2004, 08:21 AM   #1
I think the answer to this is probably yes, but is it possible to record in CF25 HDV (or CF30 on an NTSC camera) and then have it capture to your NLE as a standard DV stream? I was quite impressed with the 1080i>480i footage that was shown here:
http://www.dvinfo.net/conf/showthread.php?s=&threadid=35783&highlight=480i
So I was curious to know if capturing in CF25 and then editing in standard DV might be a possible workflow. Several people have stated that CF25 might be the best way to record images if you want to make narrative films with a "filmlook" and all the stuff that comes with that line of production.
Hayden Rivers is offline   Reply With Quote
Old December 4th, 2004, 03:10 PM   #2
Barry Wan Kenobi
It's 100% possible to capture HDV clips as DV mode. The camera does downsampling internally, so you can output HDV on the firewire as standard DV.
Old December 4th, 2004, 03:18 PM   #3
Agreed, it works fine. You'll need to tell your NLE that the footage is progressive (i.e., set field order to "progressive") otherwise it will probably interpret it as interlaced. Unless the camera marks the headers properly, which I have not tested.
///d@
Sony Media Software
Dennis Adams is offline   Reply
