telephoto options at DVinfo.net
Old December 5th, 2004, 06:57 PM   #1
telephoto options
Great camera but lacking telephoto.
Century is still a while from having their 1.6 available and even then I could do with more length to get closer to the action.
Another option is to source a long (300-500mm) photography lens and use an adapter to make it work on the FX1.
Has anyone done this?
Can you provide an expanation, details and links to a solution?
Any alternative solutions?
Costings?
cheers
Wes Greene is offline   Reply With Quote
Old December 15th, 2004, 04:35 PM   #2
Telephoto Lens For HDR-FX1
Telephoto Lens For HDR-FX1-
any suggestions? also what is the lens size i am looking for? 73mm? thanks
joel
Joel Corral is offline   Reply With Quote
Old December 15th, 2004, 04:37 PM   #3
While using a camera lens would be a great idea- since Sony doesn't make SLR's what lens would they support?
Also it would require making an adapter that allows the lens' rear element to get as close as possible to the CCD array....I really doubt this could happen without a complete redesign of the FX..........great idea in theory but I doubt Sony would be the co. to get it done- now Canon is a diff story- they could pull it off if they chose that direction- they make lenses and the XL series used an EF adapter which allowed slr lenses...
...we can still dream!
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old December 15th, 2004, 04:58 PM   #4
Barry Wan Kenobi
72mm. But there are no quality teleconverters out yet -- Century has a 1.6 that they're working on converting for the FX1 (I believe) but I don't know if it'll have the clarity of glass you'll need for best results with HDV resolution. I'm sure they wouldn't release the product unless it was up to standards.
You'll see lots of 72mm teleconverter lenses offered on ebay, usually "Crystal Vision" or "Crystal Optics" or "Digital Optics" -- save your money, ignore those, as they just don't work.
Old December 15th, 2004, 05:49 PM   #5
thanks barry. ill just have to wait.
Old December 18th, 2004, 11:21 AM   #6
Century Optics
The Century 1.6X Tele-photo Converter is compatible (optically) with the new Sony HDV cameras. The results are excellent.
The unit mounts using the the bayonets that secure the factory supplied sunshade. We have just started delivering them, tho availability will be limited for a bit, until production is up to speed.
You should contact your local dealer or Century www.centuryoptics.com for price and delivery info.
Bill Turner
Century Division
Schneider Optics
Bill Turner is offline   Reply With Quote
Old December 18th, 2004, 11:32 AM   #7
Century Optics
In another thread in this section, I announced that the Century 1.6X Telephoto is now available in a bayonet mount to fit the Sony HDV camera. The results are excellent. Contact your dealer or Century www.centuryoptics.com for info, availability will be limited for a while.
While adapting a tele-photo lens to the camera is an intriguing idea, it would involve removing the existing lens (not a solution) or a complex relay optical system ( ala Mini35 by P+S) which aside from high cost, introduces a whole new set of problems.
If extreme tele is required, your current best option is a camera with interchangeable lenses, such as the Canon XL2. If it is a rare need and you are not going to be on a remote location, renting a camera for those shots would also be an option.
Bill Turner
Century Division
Schneider Optics
Old December 18th, 2004, 12:03 PM   #8
Bill,
I can't find any information on this lens on your web site. is there a part # for this when calling my dealer?
Mike Tiffee is offline   Reply With Quote
Old December 18th, 2004, 04:56 PM   #9
Century Optics
You are correct, we haven't added the info on the Sony HDV accessories to the website yet.
The stock number for the Century 1.6 tele-converter is:
0VS-16TC-HDV and the list price is $995.
If you go to the PRO DV section of video accessories and look at the those for the Panasonic DVX100/100A all the dimensional and other info is the same. Because the Sony camera has a 12X lens as opposed to the 10X on the Panasonic, the maximum magnification is a bit higher.
Bill Turner
Century Division
Schneider Optics
Old December 19th, 2004, 03:23 PM   #10
not to go OT but will century be producing a fisheye lens for the FX1 that will not vignette?
Evan Estay is offline   Reply With Quote
Old December 19th, 2004, 04:05 PM   #11
Century Optics
We have done a preliminary design, but to produce an ultrafisheye, similar to the one we make for the Sony PD150/170 and the Canon GL1/2 for the larger, wider lens on the Sony HDV camera will require something much larger, heavier and considerably more expensive that the current model.
We are continueing to look at the problem and see if a more compact solution can be found.
The smaller fisheye that is currently in production for the HDV Sony does not have quite the coverage that an Ultra Fisheye would, but is quite nice on the Sony HDV cameras.
Bill Turner
Century Division
Schneider Optics
Old December 19th, 2004, 04:55 PM   #12
Thanks for your input Bill.
Are you referring to the fisheye adapter listed on the century website?
I am looking to purchase some kind of fisheye and the 1.6 teleconverter this month for my new FX1. Is there somewhere around town (Hollywood/Burbank...really wherever in LA) where I can inspect the adapters and try them out on the camera before I purchase?
Again, thank you for your assitance, I look forward to getting these goodies and more (mattebox anyone? :P) from you guys in the next 2 months, I have had good experiences with your optics before
Old December 19th, 2004, 10:23 PM   #13
Century Optics
If you are in the Los Angeles area, why not consider coming by our office/factory in Van Nuys? We would be glad to let you check out any of the products. The office is open M-F 8-4:30 ( I would recomment calling first to insure someone will be available to help you).
If you call the office 818-766-3715 , and ask for sales, they should be able to tell you if anyone in the LA area may have the units in stock-- but they are so new we have not delivered too many yet.
Bill Turner
Century Division
Schneider Optics
