FX1 Problem Getting HDV > DV out at DVinfo.net
Old March 10th, 2005, 08:23 AM   #1
Anyone else have this problem? The menu say to disconnect the ILink (firewire) cable, but it is already disconeected.
I want to capture to PP1.5.1 in DV.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old March 10th, 2005, 08:24 PM   #2
That message is basically telling you it WILL disconnect it then reconnect it if you hit "OK" while plugged up. and also it's basically telling you to HAVE it disconnected before you click "OK" if possible, thats all.
- ShannonRawls.com
Shannon Rawls is offline   Reply With Quote
Old March 12th, 2005, 04:05 AM   #3
this is confusing message anyhow. but it works normally.
you have normal hdv-->dv downconversion
filip
in kino (sic!) veritas
Filip Kovcin is offline   Reply With Quote
Old March 16th, 2005, 11:08 AM   #4
i was lame and had this problem. unplu the i.link cable and make sure that HDV>DV is on then you may have to reboot, i did then all was ok.
joel
Joel Corral is offline   Reply
